Question about Brother HL 5250DN Laser Printer
Yeah, I have the HL-5250DN printer. The light
Yeah, I have the HL-5250DN printer. The light indicator for the drum keeps flashing on and off. I checked the drum nothing wrong. Still keeps flashing. I printed out the setting for the printer and it shows the remaining life of the drum at 5.6%. I replaced the drum with a new one and still got the same problem. Any solutions?
  • moorecourt May 18, 2009
    I have the same problem. I replaced the drum with a new one. The problem persists. I printed less than one toner cart. on this new drum and it started printing some sort of mark on the bottom of every page after 3/4 of the toner was gone. So after less than one toner cart. used on the drum, I purchased another drum. I have printed 16 pages and the toner light has been flashing since the beginning. No wierd printing yet.
Brother hl-5250 dn printer drum problem how to solved
Posted on Dec 09, 2011
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
Posted on May 26, 2009
Error e51
All four LED's flashing together indicate an error that cannot be cleared by an end user. Normally a service call will be required.
I would recommend getting in touch with Brother or a printer technician.
Mar 26, 2013 | Brother HL 5250DN Laser Printer
I have a brother 5250dn printer that's on strike right now. At first it wouldn't print indicating a drum problem. We addressed that issue by resetting the drum counter (took out the toner/drum and held...
Try this.... no guarantees but I have seen this work.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jan 19, 2011 | Brother HL 5250DN Laser Printer
I've installed a new drum AND a new toner cartridge. have followed all directions to reset the drum and the light still flashes and I can't print, this is for a brother HL-5250DN printer
Try this....
Jul 20, 2010 | Brother HL 5250DN Laser Printer
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
Brother HL5250DN PRINTER THE DRUM LIGHT KEEPS ON
it has a drum sensor ,it was disable to work but it look like new please change ot replace drum unite not only drum total unite then solve your problem
thanks Tareq
Nov 11, 2009 | Brother HL 5250DN Laser Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Drum light will not go off
Open front cover of the printer, Press and hold down the GO button until all the LEDs light up, once all are lit release to GO button
Mar 18, 2009 | Brother HL 5250DN Laser Printer
Drum
You just need to reset your drum counter. To do that, open up the printer and hold down the Go button for a few seconds, until the LED lights all light up (the toner, drum, and paper lights all should turn yellow). That should do the trick!
Feb 16, 2009 | Brother HL 5250DN Laser Printer
"Drum" light is on.
THAT MEANS YOUR DRAM LIFE IS END. YOU NEED TO CHANGE YOUR DRAM.
Jan 29, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250DN
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Sep 01, 2007 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
1,210 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
