Question about Hitachi 53FDX01B 53" Rear Projection Television
57 hitachi ultravsion rear proj hdtv :ps3 hdmi issues
I have a ps3 hooked up via hmdi on the 57 inch rear hitachi ultravision...in blu ray and video game the screen will shift around, go black, and my tv will also shut off at times!...when i turn tv off then back on the picture is fixed...have not tried via component cables..picture never looses color or pixelate, but is not acting normal..what can be the issue?? does this have anything to do witht he upgrade port on back?
    Genius:
  • 1,148 Answers
TRY ON THE DISPLAY PS3 SETINGS TO NOT LET THE HDMI DO AUTOMATIC,,CHECK OFF A FEW ,,LIKE TRY JUST DION IT CUSTOM,,CHECK 480P,,AND 1080I,,,NOT 720P OR 1080P,,TRY THAT AND IF YOUR TV IS A 1080P,,JUST CHECK THAT,,OR IF ITS A 1080I,,JUST THAT
Posted on May 15, 2009
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Hdmi input
the best is a AV1,AV2 input as compatible input for non dedicated devices, as VCR, DVD,...
Dec 22, 2009 | Hitachi 57F510 57" Rear Projection...
Blue Ray Hookup
i have a ps3 hooked up to mine and the blue ray works very good connected using hdmi cable, converters work good also just purchased Hisense HDTV Tuner for mine
Dec 30, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
DVI/HDMI Cable lost my pic and sound
Try disconnecting the hdmI cable and the dvr box.
Connect the cable directly to the cable input.
Sometimes the dvr boxes will cause this problem
after you connect the hdmi cable.
Dec 09, 2008 | Hitachi 57F500 57" Rear Projection...
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
Ps3 problems
my surround sound doesnt work when i plug in the hmdi cable help pls
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Hitachi 53FDX01B 53" Rear Projection Television Logo
651 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
