Question about Radio Shack Pro-94 Scanner
My scanner is locked on hypersearch. How do I get
My scanner is locked on hypersearch. How do I get it off of it? Thanks
    Problem Solver:
  • 9 Answers
Answer: Hypersearch can only be turned on and off through a limit or direct search. To turn it off, you should do the following: Through Limit Search:
  1. Press PROG, then LIMIT (SRC). Lo and 29.000 MHz appear. 29.000 MHz is the low end of the scanner's range.
  2. Enter the frequency that is the lower limit of the range you want to search (including the decimal point), then press E (SVC).
  3. Press LIMIT (SRC). Hi and 1300.00 MHz appear. 1300.000 MHz is the upper limit of the scanner's range.
  4. Enter the frequency that is the upper limit of the range you want to search (including the decimal point), then press E (SVC) again.
  5. Press \/ to search from the upper to the lower limit or /\ to search from the lower to the upper limit.
  6. While the scanner is searching or is on a transmission, press H/S.
  7. HYPER should disappear from the display.
Through Direct Search:
  1. Press MAN.
  2. Enter the frequency you want to start from using the number keys. (Press . to enter a decimal point). NOTE: To start the search from a frequency already stored in one of your scanner's channels, press MAN or PROG. Then use the number keys to enter the channel number and then press MAN or PROG again. If you enter an invalid frequency, the scanner displays Error. Press MON/CLR (.).
  3. Press \/ to search downward or /\ to search upward from the selected frequency. -d-, SEARCH, and either \/ or /\ appear.
  4. While the scanner is searching or is on a transmission, press H/S.
  5. HYPER should disappear from the display.
Posted on May 15, 2009
What is the hyper symbol on the display
Click here for your manual.
HYPER appears when scanning; while Hypersearch is active during a direct or limit search.
Hypersearch
- lets you set the scanner to search at
up to 300 steps per second in frequency bands with 5
kHz steps, compared to the normal search speed of
100 steps per second.
Hyperscan - the scanner automatically scans up to
50 channels per second to help you quickly find interesting broadcasts.
Jan 26, 2013 | Radio Shack Pro-94 Scanner
I just installed my new Canon LiDE 110 scanner. I slid the lock button to the unlock position. When I try to scan, I get the following error: "Release the lock switch, detach USB cable and...
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Aug 15, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
I cannot use scanner Lide 25.. because show error : "release the lock switch,detach the I/F cable and reconnect" How solution?
Sounds like the scan head is locked. This is usually done so you can transport the scanner without bouncing the scan head out of alignment. Look under the scanner and you will see it. Make sure it's in the UNLOCKED position. You may need to power the unit off/on to reset it or restart your computer to get a fresh attempt at the scanner.
Mar 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
HI THERE HOW DO I LOCK NUMBERS /NUMBER INTO MY SCANNER EXAMPLES 468725 MY PRODUCT IS A UNIDEN BC60XLT SCANNER
Hi,my name is John.Welcome to FixYa. You have to enter the decimal point in the frequency. Press the . button. If you want to lock it, press the LOCK button. thanks for choosing FixYa...John
Nov 26, 2010 | Uniden BC60XLT-1 Handheld Scanner
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
L-1 error code.
Turn the copier off and remove the scanner glass. Sometimes the ribbon cable underneath the scanner gets bound up on the scanner. Flatten it out and secure it with scotch tape. make sure that the loop has enough slack on it for the scanner to travel freely.
Oct 06, 2008 | Sharp AR-153E Copier
Samsung CLX-2160N Sanner Locked
Same problem thanks for ignoring guys!
Dec 11, 2007 | Samsung CLX-2160N All-In-One Printer
Dell A940 - Unlock Scanner then press power
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Scanner Locked
On the underside of the scanner assembly is a LOCK, it has two positions LOCK and UNLOCK. The manufacturer sets it to lock so the scanner doesn't move during shipment. You should be able to slide this to the unlock position.
Jun 12, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Scanner lock is on
Do you not have a manual or 'get you started sheet?' It is the first thing you do when unpacking a scanner is to unlock the shipping lock. In all probability it is under the scanner base so if it is a lifting item[to access the printer] check there,or on the backplate of the scanner where all the sockets are. Failing that get onto the Tech support site at Canon.
May 16, 2007 | Canon MP830 All-In-One Printer
Radio Shack Pro-94 Scanner Logo
156 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
