Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
How to connect fm wire to recive fm signal - Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
    Scholar:
  • 96 Answers
Most after market stereos require an adapter to go from the large factory style plugs to the smaller plug for the stereo. Best Buy or any electronics store should have these. I think even Wal-Mart sells them. Hope this helps :)
Posted on May 15, 2009
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
I can't get the AM radio to find a signal. All other components work fine.
Hello
If you get FM radio stations, and only AM reception is immpossible, check whether AM loop antenna has connected to the respective poles at the back side. If it is connected, and still you do not get the Amplitude Modulation [AM] signals, check the input settings of the device is correct to recive AM. There will be a slelection option, for AM & FM. OK.
Jan 22, 2012 | Audio Players & Recorders
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    My dodge wire diagram for an 04 dodge ram does not match the wires in the dash color wise. i have power to the kenwood reciver but no speaker output in the truck only subs and amp have sound
    wire diagrams for both your truck and any kenwood deck they will all be the same
    or you can find the speakrs unmask them turn them over and look at the wires conneted to them then match them up with the wires you need to connect the cd player harness
    Jun 19, 2010 | Kenwood KDC-138 FM / AM Receiver
    Someone give me a tv antena can i make it a fm radio antena it has no wireing on it if i can how do i run the wire ?
    there is bended rod called as dipole in ur antenna..both ends of dipole should be connected by a coaxial cable. connect it to ur fm recivers antenna. to have much gain cut both ends of directors which are strait pipes (2 to 3 cm)
    Mar 10, 2010 | Televison & Video
    Receiver does not recognize AM/FM signal.
    From what I know all receivers need an antenna, there should be a connection in the back for one. Sometimes you can just use a piece of wire if you live in a large city.
    Nov 28, 2009 | Kenwood 104AR Receiver
    Can't Get A Radio Signal When I Connect A Cox Cable
    Hi...
    Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
    One of those is your problem.
    You'll need to buy a FM antenna
    Jul 25, 2008 | Sony STR-DE597 Receiver
    Tuner trouble
    This reciver has an RF FET front end. Most manuafacturers use a tuner assembly built by another company. These front ends on these tuner assemblies do go bad from time to time, and sometimes is caused by excessive static electricity. The cost to replace and or repair this front end assembly, will most likly exceed the cost of a new unit, unless you really like it. What I have seen a few people do is buy an inexpensive reciver or tuner, and use one of the unused inputs to play the AM/FM through the reciver that does not work on the tuning. Good Luck Please dont forget to rate this thread.
    Dec 11, 2006 | Harman Kardon AVR 230 Receiver
    FM RADIO DONT WORK..MODERATE AM
    hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
    Mar 26, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
    Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
    110 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Michael Kovalik III
    Michael Kovalik III
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
