Question about E-Machines eMachines Desktop PC
Usb power surge problem
IT IS SAYING THAT MY USB HAS A POWER SURGE PROBLEM. BUT THERE IS NOTHING PLUG-IN THE USB PORTS. HELP
  • wellofwaters May 15, 2009
    Great. Thank you for your help.
  • 117 Answers
Disable and remove all the usb ports from the device manager then reinstall them else install a fresh OS
Posted on May 15, 2009
2 Suggested Answers
SOURCE: I bought a Simpletech signature
Your USB port is incapable of supplying the required amps of power. ALL these little 2.5" drives need up to 1000 milliamps of juice, regardless of who makes them. I have yet to find any PC that can supply more than 500ma from a single USB port (and even that is optimistic). That is precisely why several portable drive manufacturers supply a USB splitter lead to facilitate an extra 500ma of power. (But some charge extra for this lead).
SImpletech supply the splitter lead with the drive, so please try it, as it may solve the problem.
In addition, some makers, including Simpletech, provide a 5 volt auxiliary power socket on the drive case in (unacknowledged) admission that many people do not have a second spare USB port and that, even if they have, it isn't a reliable source of power anyway! Also, they don't supply the necessary PSU and they deliberately withhold the necessary specification for the needed PSU. You need a 5 volt, 1000 milliamp power adapter costing anything from $10 to $30 (ridiculous!)
These solutions should be tried before assuming the PCs USB port is faulty, because it 'probably' isn't.
Posted on Jun 23, 2008
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
Power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
May 26, 2009 | Microsoft Windows XP Home Edition
Nothing hooked up to usb ports but computer tells me power surge
umm, usually you can't. your board is probably feeding too much current/voltage to the usb ports or someone shoved a paperclip into the port and shorted it out (frying the power supply to the usb ports) in any case, you will probably need a new motherboard or power supply.
May 26, 2009 | E-Machines T2682 PC Desktop
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Helpp! exceeded the power limits on its hub port?
try to change a new USB cord, and if it does not work the problem is a device then
Jun 21, 2008 | Vivitar MAGNACAM Binocular
Power Surge Problem
I have a Dell 5100C desktop computer. There was a power serge and now the on/off button just blinks.
How do I fix it?
stag910@aol.com
Jan 05, 2008 | Denon AVR-987 Receiver
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
May 15, 2007 | HP Deskjet 5440 InkJet Photo Printer
a simple solution is buy a powered usb hub ( which has an adapter which plugs into the mains) that should solve your problem
Dec 11, 2006 | Nikon Coolpix 5900 Digital Camera
E-Machines eMachines Desktop PC Logo
159 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
