Question about Hampton Bay 13087 70450 Carousel II Ceiling Fan
Receiver won't fit Model 52-CS
I can not fit the remote control receiver into my Hampton Bay model 52-CS. What am I doing wrong?
  • 323 Answers
Turn the breaker off first.
You'll have to take the fan down and of course disconnect the wires. I run into this a lot. What I do is take a razor knife and cut carefully into the ceiling on the side of the box, Then connect the wires from the box to the remote module with wire nuts. I always wrap them in a couple turns of eletricians tape.
Then connect the long wires to the other end of the module and push it up through the slot I cut out and lay it flat on the top side of the ceiling.
When you put it back together the part that goes against the ceiling will cover the hole in the sheet rock. Pain in the rear, huh?
Sirwriter
Posted on May 15, 2009
I have a 52 inch Hampton bay fan with remote control that will not work. model AC55200 SN002469B remote #G9P2BTAUC7052T. have put new batt in remote. will work light sometimes .No fan operation
This could be a defective receiver but if you are mixing wall switch operation with pull chain operation it may be getting confused. My local "big box" retailer sells complete Hampton Bay replacements for both remote control and receiver so ultimately that may be what's needed.
Dec 12, 2017 | Hampton Bay Dryers
Installing a Hampton Bay Trieste ceiling fan, and I don't know where to locate the remote receiver. It doesn't seem to fit in the canopy or the fan base. It is rectangle shaped about the size
If it's a thin rectangular receiver (probably has UC7067 printed on it) It "slides" into the mounting bracket up by the electrical box. If this doesn't help you can call toll free 1-866-600-3267 at http://www.fanmanlighting.com/default.asp and ask for Jack Jr
Oct 15, 2012 | Hampton Bay Ceiling Fan. Trieste 52 in....
Hampton bay uc7078T remote with uc7083T receiver ?
read your instruction manual download from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 29, 2012 | Universal Remote Control Hampton Bay...
Where can I find a remote control for Hampton Bay Model # UC7078T?
As far as I know, the kits sold at Home Depot that are labeled "Hampton Bay" should work on any of their models. The critical point is making sure the receiver module fits in the ceiling mount -- and I've never had a case where it hasn't fit. In any case, it's a mounting issue and not a fan model issue.
My usual challenge is knowing which orientation to place the module into the mount. I've found that in most (if not all) cases, holding the bigger end with my right hand and having the flat part facing up fits nicely. (The antenna will be on the leading edge, so guide it through the mount.)
Jul 10, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton bay fan model 761 567 running faster on
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The receiver is located in the upper portion of the housing for the fan motor. Look for a semi-circular black control box (usually manufactured by Rhine)
Jun 05, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Hampton Bay Deluxe Ceiling Fan SKU: 293972 Never got any but high speed. receiver # as-cf118??remote has 3 speeds. What is wrong?
you need a new remote and receiver. mine did the same thing after a few months an then it completely burntout in 2 yrs
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
Model 740 154 Hampton bay Mediterranean ceiling fan
Make sure the switches in the remote and the receiver board inside the fan canopy are set to 3
Sep 06, 2009 | Hampton Bay 52 In. 5-Blade Ceiling Fan,...
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
Hampton bay ceiling fan (7030T) remote does not work.
This symptom is usually caused by either a bad receiver or bad transmitter. Install a new remote system (receiver & transmitter).
Apr 20, 2009 | Hampton Bay 52 In. White Redington...
52" Romano Hampton Bay Fan
I have the same problem and I notice that the fan goes in reverse when I turn off and back on. I have not found the solution yet but I would say that the remote has factory defects.
Aug 18, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Hampton Bay 13087 70450 Carousel II Ceiling Fan Logo
1,030 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
