Question about KitchenAid Pro Line Coffeemaker Coffee Maker
Need To Turn Off Beeping After Coffee Brews
Can you turn off the 3 beep alarm after the maker finishes a brew? If so, how?
  • Anonymous Mar 28, 2014
    Machine has power but it is not heating water and it is not brewing.
On my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
Posted on Dec 21, 2009
  • 145 Answers
I'm sorry. There is no programming function on a Kitchenaid coffee maker that allows the beeping to be turned off.
Posted on Jul 08, 2009
Unit turns on. no water comes through but beeps as though brewing is finished.
The water line could be broke or clogged and putting the hot water back into the reservoir.
Nov 15, 2015 | Cuisinart DCC-1200 Coffee Maker
My mr coffee optimal brew just beeps constant when you press the brew now button
My hubbub and I "downgraded" to an "upgraded" Cuisinart to Mr. Coffee Optimal Brew 12 cup carafe, mainly d/t the carafe keeping the coffee hot with no burn taste and the stylish st. steel carafe. We've had 2 cuisinart's and both gave us leaking issues after 3 years of hard use (2 pots daily). The cuisinart leaked and also had the burned coffee taste, We unpacked the Mr. Coffee, cleaned all parts, after several attempts, finally stopped beeping and ran the first clean cycle. We are past ready for a great cup of joe...NO.pot ready, grounds in, attempt to turn it on and...that beeping almost got and may still get this apparatus taken back, traded, gone....but after reading my book that never says a word about beeping, I googled and saw MDLS1 replied and while I thought it was crazy I was not giving up without pulling out crazy, and it worked. After a solid hour, I found an answer... You can't just tap it here and there, I took resevoir off, banged it good, forceful but not to hurt my hand, took the basket out and banged the top and clapped around all sides, filled her up, turned it on and walla.made a perfect 10 cup = about 5 "normal" cups of joe, and it was good...pot made in 8-9 minutes, stayed hot over an hour when it was finished. Tonight, I have a hot cup, hubbub got his,and we are happy campers...however, one more beep and it's gone.
Dec 06, 2013 | Mr. Coffee 10-Cup OptimalBrew Thermal...
Why does my DGB-300 grind coffee but doesn't brew?
having no idea where it get water from does not help us figure it out , would suggest checking with the manufacturer's website for technical support .but 15 years is a good long life . some burn out in only 3 or 4 yrs
Sep 17, 2017 | Cuisinart DGB-300 Coffee Maker
Repair mr. Coffee pump
Rare for a Mr. Coffee, but it sounds to me like your disc thermostat is stuck open, or a wire has dropped off. They usually stick closed and burn out the thermal cutouts.
Feb 19, 2013 | Mr. Coffee Coffee Makers & Espresso...
My kenmore 12 - cup coffeemaker, model # 80666 is beeping every few minutes. I hit the brew button but nothing happens
In the manual that came with the coffee maker, the beeping is the freshness alert. When coffee is finished brewing it beeps 5 times. Every 15 minutes it beeps to let you know your coffee is 15 minutes less fresh! I just purchased this coffee maker and was looking on here how to dis-assemble the beeper. Whomever came up with the "freshness beeper" on a coffee pot needs a new job! Usually when I make coffee the whole house is asleep, now the beeping is waking everyone up! Very frustrated with this coffee pot!
Nov 02, 2009 | Kenmore Coffee Makers & Espresso Machines
Coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Jan 12, 2009 | GE 106591 Coffee Maker
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
Turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Mar 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
KitchenAid Pro Line Coffeemaker Coffee Maker Logo
2,657 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Ismael Rodriguez...
Sal De
Craig Butler
Craig Butler
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
