Question about Frigidaire FEF366EC 30" Freestanding Self-Clean Electric Range w/ Advanced Bake Cooking System & 4 Radiant Elements: Stainless Steel Kitchen Range
Surface of stove heats very hot when oven is on.
The surface of the stove heats very hot when the oven is being used, even when stove burners are not being used. Brand new Frigidaire electric range.
  • oaxacagirl May 15, 2009
    It just seems very dangerous to have the stove top blazing hot when, say, cooking a turkey for 4 hours...can this be right?
    President:
  • 2,559 Answers
This is normal and designed to do so.
Posted on May 15, 2009
  • Randy Hough
    Randy Hough May 15, 2009
    Yes it actually help dissipate the heat upward rather than towards the surrounding cabinets and wall.
Is it normal for my frigidare gas cook top get hot when i am using the convection oven?
Posted on Oct 21, 2014
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Why surface control knobs become hot when oven is on
If its an older model gas stove, then its normal. I have an older gas stove and the knobs get a little hot when the oven is on. Nothing that prevents me from using it, but enough to notice they are warm.
If its a newer stove, you should contact the manufacturer. Without knowing more info, I can only give a general answer.
If you're renting in an apartment then talk to the management or maintenance. If you're leasing the stove, call the company its being leased from.
Sep 30, 2015 | Kitchen Ranges
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
I have a gas oven whirlpool sf3020ekq2 buners work but oven won't
Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
If unit is old and you don't like it anyway maybe santa would be good to you and replace the stove oven. The gas valve is about 60 bucks or so and hot surface is about 20 bucks. let me know how it turns out.. ken
Dec 16, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire FEF366EC 30" Freestanding Self-Clean Electric Range w/ Advanced Bake Cooking System & 4 Radiant Elements: Stainless Steel Kitchen Range Logo
2,348 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
