Question about iLO (2 GB) MP3 Player
I cant find any USB port iin my mp3 how do i charge it using USB cable
  • 51 Answers
Must be hidden with a small button-like flap which can be pulled out using your finger tips...should also have a usb symbol on top so that it is obvious to all.....if you can still not find it....try moving your finger gently along the periphery of the player...any breaks or changes in level should show you your destination...
Posted on May 15, 2009
How do you charge the battery?
MP3 players are usually charged using the supplied USB cable. Connect the USB cable to the MP3 player and then plug the other end of the USB cable into the USB port of a working computer.
Jun 01, 2012 | SanDisk Sansa c200 MP3 Player
How do i charge my craig mp3 touch
The MP3 player is charged by connecting the supplied USB cable to the MP3 player and then plugging the other end of the USB cable into the USB port of a working computer.
This cable is also used to copy files from the computer to the MP3 player.
Dec 27, 2011 | Craig Audio Players & Recorders
I dont how charge battery on my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Audio Players & Recorders
How dont know how to charge my mp3 player
Dec 25, 2010 | Philips GoGear Flash MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My thing that hooks up from the mp3 to the computer wont work or somthing every time i plug it in it doesnt charge and the computer doesnt aknowledge it also i cant open up the phillips mp3 on my computer
If it's a standard cable, it's a USB to mini USB cable. Have you tried a different cable with similar ends? Also, have you tried a different USB port on your computer?
Apr 24, 2009 | Philips HDD1630 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Battery
Latest firmware
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
Please Help
Hello Pookie34,
In general, most MP3 players are charged by connecting them to the USB port on your computer using the supplied programming cable. Make sure you are connecting the cable to a USB port on the computer itself and not a USB hub as most USB hubs do not have enough output power to charge your device.
Your MP3 player can also probably be charged by connecting it to an appropriate AC wall charger or automobile power cable. However, for most manufacturers these are optional accessories not normally included with the player.
Best Regards.
Ken
"Go Ahead. Use Us."
Jul 22, 2008 | Memorex MMP8565 MP3 Player
Cant find usb port on mp3 player
if you got it new it would have come in a box with the usb cable (pc to MP3). Plug cable into bottom of mp3 and usb end into your PC. This will charge it up
Nov 13, 2007 | Audio Players & Recorders
iLO (2 GB) MP3 Player Logo
55 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
