Question about Maytag Washing Machines
Replaced wosher 's door boot drain
Hi . I,m Russle .Can yuo help me? I wont replaced kit, door boot drain for wosher Maytag mod# MAH4000AWQ part #AP4010226 or 12002533 .If you will show or exsplain step to step me I will be so happi.Thank you so match.
  • ruslan pimutkin May 15, 2009
    Sorry ,but I wont know step by step haw its go replaced . I did know the link which you did send me I dont got it haw needs do it?
    President:
  • 2,923 Answers
Hello Russle,
Here, I provided you the link where you can find the step-by-step assembly of the machine. All you have to do is to locate the problem on the picture that you would like to troubleshoot and then click the Blue link:
Here's the link:
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=MAH4000AWQ&mfgModelNum=&fkMfgID=1
Have a great day!
Posted on May 15, 2009
Maytag Neptune MAH4000AWQ
If the appliance does not complete the cycle, then it is probably a fault on the control timer, the part should be replaced.
Oct 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Why did the Q6 component blow on the circuit board
I`m not sure which component you refer to by "Q6", but typically on the Maytag Neptune washer it is the resistors associated with the door lock assembly which burn out on the "machine control board" (not to be confused with the "motor control board" located under the basket/tub inside the cabinet). It should look like the image below.
You can usually examine the control via a visual inspection to confirm or dismiss any damage. Look for any sign of burnt resistor's, specifically one identified as R11 and one as R75 they are both part of the lock circuit and if damaged will prevent the washer from draining and spinning properly because the door lock won't engage. The control will need to be replaced if damaged as will the latch wax motor. (Unless you can identify the value of the resistor`s and take a gamble on a repair)
Check with a local or on-line part depot with your model number for specific part number's. Hope that help's, let me know. Thank's for visiting "fixya" and if this was helpful please leave a rating for the info I provided. Thank's again and good luck. macmarkus :)
Feb 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Water leaking from lower connection of tub coming from pressure switch.
Hi, If you remove the screws on each side of the door opening, the front panel will come free. You might be able to lok in and see the preasure hose. Id the hose leaking or the cup it attaches to?
I hope this helps. Please let me know if I can assist you further. Thanks
Vic
May 23, 2009 | Maytag Neptune Washer
Maytag neptune washer model #MAH4000AWQ
The famous Q6 and R11 failure can cause this issue. Have you replaced the faulty door latch wax motor yet? See www.neptunehelpsong.com for a video that explains what happens.
The Q3 triac (same part as the Q6 triac) will need to be changed on the board or the control board will have to be replaced along with the door latch wax motor if yours has the brownish color actuator pin. The new design has a black actuator pin.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MAH4000AWQ
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Jun 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
