Question about Car Audio & Video
My rear speaker in my 2001 buick regal is blown. how do I remove the old one to put in a new one. it is a monsoon system
  • 3,866 Answers
Ok open the trunk there should be two little boxes on the left and right there are little screw like ties on there twist themclockwise and you hshould be able to pull the speaker box out and unplug the speaker and replace it.. We get comsensated on your ratings so please rate nice Thanks
Posted on May 15, 2009
Do you know what size the door speakers are in an 8 speaker monsoon system in a 2002 Buick Regal? Also, do you know what size the tweeters are?
I recommend you visit www.crutchfield.com They have an extensive library of vehicles and systems and will tell you what size speakers your vehicle has and recommends replacements. hope this helps
Aug 30, 2011 | Car Audio & Video
Will any 6x9 speakers fit my 2002 pontiac grand am in the rear deck?
I recently helped to replace the rear speakers in a 2001 (or 2002?) Grand Am GT.
It depends on the type of stereo you have. Look at the wires going to the rear speakers. If there are two wires to each, I'm pretty sure that almost any 6X9 speaker will work.
My friend had a Monsoon system, and there were 4 wires at each speaker. There are only a few speakers that can be used on this system. As I recall, the ohm resistance is different from typical speakers. If you have a 4-wire system, you should do some reading at these websites to see what speakers to use:
http://www.gaownersclub.com/forum/index.php
http://www.grandamgt.com/
or try http://www.crutchfield.com/
I did read at one of the above Forums that there are GM replacement speakers (better than original):
"I just ordered two new Monsoon rear speakers from www.gmpartsdirect and they were only $85 shipped. They are a new part number which have been updated with better cones to help prevent blowing, part number is 22698418 " If you go with GM Monsson speakers, also try Ebay. Good Luck.
Apr 08, 2011 | Pontiac Grand Am Cars & Trucks
01 camaro stereo wiring diagram monsoon system
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Mar 15, 2011 | 2001 Chevrolet Camaro
How to change the battery on 2001 buick regal
open hood
locate battery
disconnect positive wires from post
disconnect negative wires from post
pull out old battery
put in new battery
reinstall wires to posts
Jan 03, 2011 | 2001 Buick Regal
Rear speakers blew out in 2001 Buick Regal -How do i remove them?
You have to remove the back "deck" from inside the car
Mar 02, 2010 | 2001 Buick Regal
1997 Buick Regal fanbelt problem
buy a new tensioner assembley and idler pully and might as well get a new belt while your at it. you will need a 3/8 ratchet a 15 mm socket and a 13 mm socket there is one bolt holding on tensioner remove it discard old tensioner put new tensioner in place and tight bolt. second remove bolt from idler pulley discard old pulley put inton place and tighen bolt. next install belt fallow belt routing digram put head of 3/8 rattachet into hole on tensioner or on bolt head of tensioner pulley depending on style of tensioner and pull or push to create slack in belt push belt into groves on all pulleys and release tensioner
Jul 31, 2009 | 1997 Buick.5 Regal
2001 Buick Regal, Rear speakers not working properly
Well the voice coils in the speakers may be fried, or on their way out. Has anyone been simply turning it up too loud, or too bassy, or at obscene levels.
May 27, 2009 | 2001 Buick Regal
Front speakers
either the wires in the boot where door folds open has broken wires in it or the most likely case you have 2 blown wolfers and 1 blown tweeter. common for cars with the monsoon stereo system, they made the radio better than the speakers.
Mar 09, 2009 | 2001 Volkswagen Beetle
After Market radio install on a 2001 Passat
Metra makes a preamp harness that you can use if you have the partial Bose system. My A4 had that (where the front speakers were run off of the headunit with speaker-level feed, but the deck put a line level signal to a rear amp to power the speakers). This harness would let you use the aftermarket deck with your factory speakers, if you have the partial Bose system. Best bet is to do a Google search for "Metra 2001 Passat" or something like that and I'm sure it'll show up.
Jul 31, 2008 | 2001 Volkswagen Passat
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
