Question about Nespresso D150 Espresso Machine
Grinds in Coffee...
Hi...
I have a Nespresso D150 and quite often I end up with grinds in the coffee.  I have cleaned all the necessary items according to the instructions several times.  When I begin to make the espresso, tho coffee seems to come our normally for about the first ounce then a spurt of water comes through that is very dark (with the grinds in it).
Any suggestions?
Thanks so much.
Scott
Make sure you have tightened the pod carrier/basket far enough. This happened to me early on, & I just needed to tighten up the pod basket. (They say you don't have to force it, but I DO force it as far as I can.)
Posted on Jun 12, 2008
Coffee is getting stuck in the shoot between the grinder and basket so coffee is very weak
Try using a bottle brush and cleaning out the residue from coffee grinding. Coffee grinds build up because of the oils in the beans. I clean mine twice a week and it works great.
Mar 05, 2016 | Kenmore 12-Cup Coffee Grinder and Brewer,...
Nespresso d150. Drips slowly
Don't know a whole lot about this machine but probably needs to be cleaned. Are there any instructions on how to clean it in you operators manual?
Nov 22, 2010 | Nespresso D150 Espresso Machine
Grinds too long coffee still weak
You can adjust the grind, finer will give you stronger coffee. Think water through sand vs. pebbles. There are also settings you can find in your owners manual for adjusting the length and strength of your "pull".
Try Julius Meinl espresso roast, it's dark, rich and sweet. Definitely my favortie.
Dec 24, 2009 | DeLonghi EAM3400 Espresso Machine
Where can I get a users manual for nespresso d150?
Try this link www.scribd.com/doc/9633532/D150InstructionManual Thats how I got one
Jul 14, 2009 | Nespresso D150 Espresso Machine
Saeco Vienna de luxe no coffee comes out
The brew unit is blocked, remove unit and then remove the screen located at the top, clean screen and reassemble.
Jul 03, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Hot steam dampens coffee grinds in grinder unit
These grinds are what is left after the grind process is finished. Everyones unit does this.
Mar 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Nespresso D150 Espresso Machine Logo
270 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
