Question about Pioneer CDJ-1000 CD Player
CDJ1000 MK2 Powers up but no display & no sound
I have a CDJ1000 MK2 which powers up but the main display nor the jog dial display power on and no sound. The buttons do work though. When I press the forward button I see the cd lens moving. Has anyone come across this problem? Any ideas?
  • bigpsi94 May 15, 2009
    This is a Pioneer CD Turntable for DJ use.
  • Blanco Cncy
    Blanco Cncy Feb 20, 2015
    did u manage 2 fix it?
Had the sam problem... Turn te player upside down, take off the bottom cover and check the semiconductor fuses located near the supply connector on the top of mainboard. The one that is responsible for display is marked as VLOD (-40V). Worked for me :)
Posted on Jan 20, 2010
  • Blanco Cncy
    CAN U SEND A PICTURE I CAN NOT LOCATE IT
    New Friend:
Did you dound the problem? i have the same one :/
Posted on Jan 13, 2013
Grabo i dont see the fuse
Posted on Jan 31, 2010
  • djrix1 Jan 31, 2010
    if anyone knows where the fuse is , send me an email
    djrix1@ gmail.com i bought the service manual, i touched metal against the circuit board display when it was on, and the results our the same no sound, no display , jog display, but powers up and reads loads the cds,
  • stephen May 14, 2015
    Did you find out were the fuse was an having the same problem
    Problem Solver:
  • 9 Answers
U have to update the firmware ..u can download it from pioneer.com
Posted on Jun 10, 2009
    Genius:
  • 1,148 Answers
IF THIS IS IN A CAR ,,TAKE OFF THE FACEPLATE,,THERE IS A LITTLE BUTTON THERE ,,PUSH IT WITH A INKPEN,,ITS A RESET
Posted on May 15, 2009
2 Suggested Answers
  • 137 Answers
SOURCE: I have a CDJ1000 MK2 which powers up but the main
removed top cover and there is a power supply that you will see on the top left side of the main chassic, check f1 fuse as that may be bad.The complete power supply board part number is DWR1344
Posted on Apr 18, 2010
How to clear codes
i found this in another place
Quick Test Mode
Note: This test erases all faults and memory:
To enter press Spin, Soil, & Power
simultaneously with the power off.
1. All LED's light up and the washer beeps as it
enters the Quick Test Mode.
2. The unit displays the software version for a
second then clears the EEprom.
3. After the displaying the software version, LCD
will display Model information.
If EEEE is displayed the PCB assembly is defective.
For production up to 03/31/2009 Serial **S3**
4. When the version is displayed. Press the following
keys to test the various components.
Effective 4/1/2009 Serial **S4 ** a change was
made.
4. After the displaying the software version, turn
the Jog dial CCW to display "F4". Press the following
Press Temp Key to cycle through the Water Valves in
this order: Cold Main, Bleach, Cold Main & Bleach for
Fabric Softener, Hot, then off.
Press Spin Key to test Motor circuit.
Press Signal Key to test Drain Pump
Press Soil to test door lock - unlock circuit
Mar 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
How do I set the date
1. Close the lens barrier and press the LCD monitor ON/OFF button to turn on the LCD monitor.
2. Press the Menu button to display the Menu.
• See page 37 for how to use the Menu.
3. Press the top/bottom arrows on the Jog dial to select MODE SETUP, then press the right arrow.
4. Select the date order using the top/bottom arrows on the Jog dial. Press the right arrow on the Jog dial to adjust the first setting month/day/year.
5. Press the top/bottom arrows on the Jog dial to adjust the first setting, then press the right arrow on the Jog dial to adjust the second setting.
Repeat until the minute is adjusted.
• 00 will appear for the year 2000.
6. Press the OK button to save the setting. Press again to cancel the Menu.
• For accurate setting, press the OK button when the clock hits
00 seconds.
• If the Menu button is pressed before the OK button, the
setting and Menu mode will be canceled
Jan 31, 2012 | Olympus D-460 Zoom Digital Camera
One of my cdj 1000 mk2 powers up,takes cds but there is no display or sound every button works on it there is just no display..can u help??how to fix or where??costs??thanks
This is either a display failure - so you need a new display board, or the little fuse on the underside board has popped. Definately a service centre issue though, happy to help more if needed :)
Aug 28, 2011 | Pioneer CDJ-1000 CD Player
My sony walkman suddenly stopped working while out on a run, On returning home I checked that it was fully charged & now it seems to do its own thing, if I can get it to work
Try resetting the Walkman by pressing the RESET button located near the Jog Dial.
Press the reset button using a sharp pointed object like a ball pen. Be sure that the Walkman is playing when resetting.
Try connecting the Walkman Player to the Computer by using the stand to charge the battery and check if it works normally.
If the issue persists after resetting, try Formatting the Player back to factory defaults. Formatting the Player will erase all the files and all the settings will be back to factory default. Please be sure that a backup is there with you before formatting the player.
To Format the Player, unite the left and right parts to turn off the Player.
Separate the left and right parts.
Press and hold the jog dial for about 15 seconds until the status lamp blinks quickly.
Release the jog lamp when the OPR Lamp lights Red.
Rotate the jog dial within 30 seconds after the OPR lamp lights Red.
The status lamp turns off and the OPR Lamp lights alternately Green and Red each time you rotate the jog dial.
Press the jog dial while the OPR Lamp lights Green.
The OPR Lamp blinks Green quickly and Formatting is executed.
When the OPR Lamp turns off, formatting is complete.
If you press the jog dial while the OPR Lamp lights Red, or if 30 seconds have passed, formatting will be canceled.
This will resolve the issue.
Thanks for using FixYa.
Dec 08, 2010 | Sony Walkman NWZ-W202 MP3 Player
My o2 xda stealth phone hanged b coz of virus help me out m not having setup cd wanna format my cell
First of all switched offf this cell u can remove its battery & put it again then wait for a 10second then do this magic
PRESS !<< & >>! & same time Press Power switch {left button in centre jog dial + right button in centre jog dial + Power Switch} & wait for a munit u ill see on screen formating at this time press Green Button thats is call button & this ill hard reset your O2 xda stealth
Mar 18, 2010 | O2 Xda Stealth Smartphone
Cdj1000 mk2 no sound, no display , jog display, but powers up
There is a line of these fuses next to the power supply connector on the main board
Jan 31, 2010 | Pioneer CDJ-1000 CD Player
I have a CDJ1000 MK2 which powers up but the main display nor the jog dial display power on and no sound. The buttons do work though. When I press the forward button I see the cd lens moving. Has anyone...
Sep 15, 2009 | Pioneer CDJ-1000 CD Player
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Need to fix date and time on Sony IT M804 phone
1) Press "Program"
2) Turn "jog dial" up until "DATE TIME! appears on the display
3) Press Jog Button
4) Enter settings by pressing dialing keys
5) Press jog button and set other parameters on the display ( step 3 - 4)
6) After last you will hear a long confirmation beep
Aug 26, 2009 | Sony IT M804 Corded Phone
Problem with cdj1000 mk2
possible faulty cable to main display or small crack or d/j on pcb.
if you havent got it repaired then you can send it to us.
thanks.
http://www.audiovisualservices.info/
Oct 29, 2008 | Pioneer CDJ-1000MKII CD Player
Pioneer CDJ-1000 CD Player Logo
2,285 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
