Question about LG WD-3274RHD Front Load Washer / Dryer
Wont turn on
Just got this used, although, it worked at her house and now wont even light up.....
  • msloo Dec 21, 2008
    Power won't come on on my machine as well.  Is there a fuse to check somewhere before we spend $375 to have a LG technician replace the board?Does anyone know where I might be able to get a repair schematic?  Thanks.
    Problem Solver:
  • 18 Answers
Washers draw a lot of current as well. You need to be sure that 1. your plug is live, and 2. the fuse is large enough that you don't trip the breaker when turning it on. If it is the dryer, you run that off of a different V altogether, so you will have to be sure that you have that capability at your house. It is a different looking plug, however, so you will notice that you can't plug it in...
Posted on Jul 21, 2009
  • 489 Answers
Check to make sure that your outlet is good.  You may need to run an extension cord to another outlet to make sure.  If the unit still doesn't turn on, you may have a problem with the control board and will need it to be serviced by a qualified LG technician.
Posted on Apr 28, 2008
Skytronic inverter 300W 12V
check for an overload button / reset switch
could be less inefficient now than when new and if the total wattage of the bulbs exceeds 280 watts then it may be burnt out
Jun 25, 2017 | Televison & Video
My dvd wont switch on
Make sure all your wires are plugged in even your HDMI to HDMI because HDMI controls itself from the TV sometimes and will let it turn on without that HDMI cable being plugged in
May 12, 2013 | Televison & Video
MALIBU 200 WATT IRON CORE TRANSFORMER MODEL NO 8100-0200-01 LIGHTS WONT TURN OFF
Plug power pack into cheap wall timer, and that will operate lights until warranty is resolved with Malibu or product-seller.
Simple power outage, or nearby lightning strike, can cause surge that will knock out digital timers. And knock out analog series power packs too.
You probably need receipt for warranty claim.
This timer is not shown on Intermatic site, and not subject to Intermatic 5-year warranty, but certainly Malibu must have a warranty of unknown length, and a corresponding claim procedure.
Double-check your installation, and additional resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Whole-house surge protection is hot item among folks these days since so many household items are now electronic, including appliances, washer-dryer, water heaters, timers, etc.
This will protect both 120Volt and 240Volt circuits, although it is unknown if your timer failed because of surge..
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Sep 29, 2012 | Hardware & Accessories
I need to find the flasher relay for a grand marquis 2001 .does it has one? My turn signals wont work I can hear the sound but don't even flash
Yes, it does have a flasher, although it may be a combined unit with the hazard flashers relay. So you hear the clicking of the flasher relay? That seems to indicate the relay is working properly. Have you checked the bulbs and the turn signal fuse? Any turn signal bulbs light up anywhere, front or back?
How about your brake lights, do they work? Your car may have separate, stand alone turn signals in the rear, but many American cars use the same bulb and same filament on the bulb for the brake lights and turn signals. If your merc is like this and the brake lights work, then the bulb must be good.
Turn on the hazard flashers and see if all bulbs work and flash at each corner of the car. This would be the same bulb as for the turn signals. If they work, it could be a bad turn signal switch, may even be the flasher relay somehow malfunctioning, and in a few cases, a bad hazard switch can affect the turn signal switch. Check fuses and bulbs first. If you have any type of body control module that controls lights and other accessories, you may have to investigate that. I know I'm not being very helpful, just throwing out a few suggestions. Good luck.
May 21, 2012 | 2001 Mercury Grand Marquis
Wont turn on again
This is not good, the circuit board that is housed with the hard drive is defective, cannot be repaired, replacement only option
Mar 10, 2012 | Buffalo Technology 1TB DriveStation...
. Hi.Have a Zanussi DI720
This is a guess but try gently moving it through the cycles by hand a few times, it may just be that the timer mechanism is stuck a bit from age and or disuse. Turning it may help to loosen it up.Be gentle though.
Jun 05, 2011 | Dishwashers
My garmin sat nuv wont turn on even after pressing
plug it in to the house or car charger for at least 4 hours, then try again. if it still wont turn on, we can try something else.
bill
Aug 31, 2009 | GPS
Saturn SC wont turn over
when it comes to DC electricity like on automobiles. DC current wants a really good connection. check and make sure the wires at the alternator you just installed are tight. check the tightness of the battery cable connections at the battery. check the tightness of the main cable that goes straight to the starter. small things like the dome lights ect.... will still work many times when the connection is not so good, but big current items like the starter need a good hard connection to work. sometimes when the connection is sub par, the starter will just make a clicking noise but wont turn over the engine.
Jun 11, 2009 | 1992 Saturn SC
Wont turn on even when plugged in
yea, you shouldn't have stole it
Feb 06, 2007 | i-mate JAMin Smartphone
LG WD-3274RHD Front Load Washer / Dryer Logo
109 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
