Question about Hitachi P50H401 50 in. Plasma HDTV
My 50' is currently set on analog preset channels...how do i make/move the button to digital instead of analog?
    Genius:
  • 1,148 Answers
TURN DIGITAL ON IN THE MENU,,SHOULD FIND WHAT U NEED THER
Posted on May 15, 2009
How to I delete an occupied preset and enter another channel
My experience has always been to replace the current station preset with the new.
I recall two process:
  1. The first locate the new station that you want and tune the radio to the station. Press and hold the specific preset for several seconds to replace the old station with the new.
  2. Tune the radio to the new station and press the set button if so equipped and than press the preset button. In some radios they have group 1 and group 2. In that case press the set button once for set 1 and press it twice for set 2 and then press the preset button.
Hope this has helped?
Jan 12, 2016 | Cars & Trucks
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
How to set presets gpx rdt4004sp
You can store up to 10 channels. For channels 1-5:: Go to station you desire. Press MEM button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels. After you store to buttons 1,2,3,4,5 then: For channels 6-10: Go to station you desire. Press MEM button. Press +5 button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels.
May 31, 2009 | GPX RDT4004SP AM/FM Radio
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Diagram
ok i am typeing this right out of the book/
operating your tv: Once you have connected your tv to an anntenna or cable system,plugged the tv in, and put batteries in the remote, you are ready to use the tv. the first thing you should do is program your tv so it memorizes all of available analog& didgital channels.PROGRAMING YOUR TVS CHANNEL MEMORY: your tvs memory determines the channels thet are available using the "up ch down" buttons. if a channel is not in memory . you can tune to it with the numbeer buttons, but not with the up and down buttons . follow these steps to program your tvs memory:
1) Preset
press the MENU button twice to enter preset menu
To memorize all available analog and didgital channels
press the ch down button to highlight FULL SCAN then press VOL.+ to begin channel scaning, the channel scanning starting with analog channels then to didgital channels. after your tv finishes memorizing the channels, it will return to normal tv viewing. I hope that this fixes your problem thats just the main section on the programing part so if you need further info just ask!
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Hitachi P50H401 50 in. Plasma HDTV Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
