The compressor only works about 15 minutes
Hi all,
At home I've an old model of Samsung of 19000 btu, it's of windows.
A few months ago it was broken, but the technician brought a new compressor and installed it. The air worked very good about four months until the last two weeks.
Until now, after switching the equipment on, the compressor cools about 15 minutes without to reach a nice temperature inside the room, after that, the equipment turns the compressor off and doesn't work again for a long time in the night, always for 10-15 minutes if works.
I've realized that, after raining, the compressor works for a long period of time. Therefore, before switching the equipment on, I wet the rear condenser with abundant water and it provides the same effect of rain.
None of the condensers should be dirty because they were cleaned with pressure water, also the front condenser was cleaned with a pink chemical that left it like a new one.
My question is, what's going on with the air if the compressor and the gas is new on it?
If you need more details, please ask...
Thanks is advance...
  • Efren Bravo Oct 15, 2007
    Here again,  there is an image of the air.
    and also, the air consumption was meter with a jucon (in spanish), and the result was of 18 ampere.
    Problem Solver:
  • 7 Answers
This unit could very well be over charged with gas and when the unit runs for about 15 mins. the pressure gets too high and cuts off on high pressure if your system does that so many times the compressor will get hot and shut off on internal over load, And will not come back on till it cools down. .... Or you may have a kink or restriction in your refrigerant lines somewhere... this would cause your compressor to also run hot and cut off on internal overload.
Posted on Oct 16, 2007
SOURCE:
Keyboard goes to sleep - Windows 7 PC not laptop
Are you able to provide a little bit more information?
When it stops working, what do you usually do to get it started again, are you rebooting the PC to get it to work again?
How old is Logitech Keyboard?
Thanks
Dec 17, 2017 | Logitech Computers & Internet
Samsung htz510 wont read dvd or cd? It just says loading for ever and then says error???
I have the same issue, along with a Rear Check issue at power up, and the fan stopped working about a month ago, so three strikes and your out, I would not recommend this product due to the quality. My Oniko was purchased years ago and is still going strong, I moved to an apartment and wanted the wireless ease with the back speakers, never again with this brand. My Samsung LCD is acting up now too, it is only 15 months old, and won't power up right away takes like 5 attempts, unreal
Aug 13, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
My refrigerator (RB1855) runs excessively long. Down time 15 minutes and run time 20 minutes. Noise comes out from the compressor. Even raiseed the temp setting (-18 to 17 and 3 to 4) when it is running...
There are about four different versions of your model. If you like I will send you the manual and we will work together as this refrigerator is very complex. Let me know, Thanks, Sea Breeze
Jul 11, 2009 | Samsung Refrigerators
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
115000 btu ready heater/ about 3 years old from home depot/multi fuel
I would try cleaning the flame sensor, use a Qtip slightly moist with ispropyl alcohol. it's a rubber boot about 2in. long faceing the combustion chamber with two wires.
Jan 15, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Frigidaire humming freezer not cold enough
    For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
    To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
    Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
    Heating & Cooling Logo
    379 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Donni Steen
    Marvin
    Marvin
