Question about JVC KD-G140 Car CD Player
Truck aftermarket stereo has power but no sound
I have a 99 Dodge Ram 2500 and I installed the stereo myself. It worked for about a month and then all of a sudden when I was driving the sound just shut off. Then every once in a while when I started my truck the sound would be back on. And the other times it would not work. Eventually it just stopped working all together, but the power was still on. All fuses are fine in the truck and back of stereo. Also I have a 4 yr warranty from bestbuy and was wondering if they would look at it. Any help would be greatly appreciated.
    President:
  • JVC Master
  • 1,348 Answers
Check the memory circuit.the usually yellow wire with the small fuse.the best thing is take it out and see if it runs on a bench.there are 2 voltages to turn on the unit,12volt main power,and memory which must be constant power otherwise the clock and the memory for the stations will reset.check the ground and all the wiring.also the factory fuse may be cracked or intermittent.i have seen intermittent fuses especially 3ag types where the fuse breaks at the cap,and the part you see through the glass looks fine.
Posted on May 15, 2009
I just got a Insignia cd/stereo/MP3 car radio and I really need an installation manual. Lots of wires, colors, don't know what they power. Where can I get the manual? It's going in my 01 Dodge Ram
Greg,
Do yourself a HUGE favor. Drop $8 on a radio wiring harness connector. You wire it to the aftermarket radio while sitting at your kitchen table. When done, yank the factory radio and simply PLUG IN the new radio directly into the truck's wiring harness. Done! No cutting of your truck's wires, splicing, taping or hanging upside-down making connections. Plus, when it's time to sell the truck - you can pull out your radio and dump the factory radio back in the truck in no time.
Stereo Wire Harness Dodge Ram Pickup 98 99 00 01 Car Radio Wiring...
You can find these at other stores locally too. Good luck!
Nov 30, 2015 | Dodge Cars & Trucks
I have a 98 dodge ram 2500 I installed a aftermarket radio and have power but no sound please help
Sounds like you hooked the wires up wrong. Crutchfeild.com sells the direct plugs that go from the deck to the stock wiring harness. Its a good investment. But check your wires.
Jan 17, 2011 | 1998 Dodge Ram 1500 4WD
1999 dodge ram 2500 turbo diesel the trailer brakes won't work and I tried a different truck to make it was not the trailer any ideas?
We just had the same problem with our 99 2500 Turbo Diesel Ram. The problem ended up being the factory trailer cord recepticle near the hitch. When we unplugged the harness from the back side of the recepticle we found that the brake terminals had gotten hot and burned out. We replaced the recepticle (about $30 from Dodge) and our problem was solved.
Jul 15, 2010 | 1999 Dodge Ram 2500 4WD
I am installing a CD player into a 1996 Dodge Ram 2500 Truck and I need the diagram
Here you go:
1996 Dodge Ram 2500 Truck Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
May 12, 2010 | 1996 Dodge Ram 2500 Club Cab
Dodge Ram 2004 no dome lights or locks when key out of ignition
Sounds like you cut into one of the wires that that supply power when the key is off....you may need to get a wiring diagram for the truck and trace the wires down.
Cutting into the wrong wires is not uncommon in todays newer cars.
Sep 15, 2009 | 2004 Dodge Ram 2500
2006 power door locks wont`work
Resistor is blown...take the truck to an automotive electronics/stereo shop that installs keyless entry systems ($89) and put an aftermarket keyless on the truck. They'll have to trouble-shoot the system to make the installation of the new keyless!
Jun 14, 2009 | 2001 Dodge Ram 1500 Truck 2WD
No spark 99 dodge ram 2500 4x4 360v8
you need to replace your crank sensor!
May 07, 2009 | 2001 Dodge Ram 2500 Truck
JVC KD-G140 Car CD Player Logo
862 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
