Question about Kenmore Washing Machines
I have a Kenmore front load washing machine model # 417.44082400. It says LOC and gives me an error when I try to turn the machine on. The door locked light does not come on. I can open and close the door, but I can't turn the washer on.
  • bcxn3 May 27, 2009
    Yes,this was very helpful. I had tried unplugging and pushing some of the buttons, but evidently not the right ones.
  • 13,433 Answers
Hey,
could it be the child lock feature?
Look for the 2 buttons on it that have a lock symbol. Push & hold both for 3 seconds. That should toggle the child lock mode.
Have you tried unplugging it for a while and see if it helps.
Posted on May 26, 2009
Flashes LOC and won't start
The solution to the "LOC" error depends on many factors, including which Elite model machine you own and the cause of the error. If your machine has an "Options" and a "Select" button, try pressing and holding these for five seconds to clear the locking error. You can also try unplugging the machine for five minutes and then plugging it back in
Nov 08, 2012 | Kenmore Elite 45986 Front Load Washer
Our kenmore supercapicity 3.5 front load washer's door look will not engage. It reads ERR and the door lock light does not go on.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 22, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
417.44092500 front load washer I get a LOC err,
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Jan 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
