Question about Hobart H600 Stand Mixer
Moving our mixer
We are moving our hobart h600. Does anyone have suggestions on how to go about it? We are moving to a new location.
    Scholar:
  • 81 Answers
Offer a free pizza night to your biggest & strongest friends and as they walk in the door tell them they can eat all they want but, they have to move your mixer in return. Most of your larger, well known rental places should have what we call in the business as roller skates or appliance moving casters. They are a tripod type heavy duty caster that is placed under each corner of the mixer and can either be strapped or bolted down. You could also call a local commercial kitchen equip service & install company like Ecolab GCS, they move & install equipment. 800-822-2303
Posted on Jul 25, 2009
How to dismantle a Hobart H600 before moving ? Hi, I need to move a 60qt mixer which is too heavy for me. Please, could you give me a way to split it into 3 or 4 parts which may be moved separately, and...
You can't. Contact professional catering removers. Or Two Men and a Truck.
There are only two parts, the head and the stand. They are pretty much equal weight.
Feb 24, 2018 | Hobart H600 Stand Mixer
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
What oil can you use for the hobart h600
on the hobart h600 we use 120 oz of 140 weight gear oil.
Mar 04, 2011 | Hobart H600 Stand Mixer
How do you change or add oil to a Hobart H600 mixer
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
Jan 02, 2010 | Hobart H600 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Reccomendations on how to move a Hobart H600 Mixer
I would use the 4 wheel platform dollies and ratcheting tie-down straps to secure it to the dollies.
I have used these to move pianos and other larger objects, but make sure that you secure the object to the dolly and get the best one with the biggest wheels that you can find. The bigger the wheel the easier the roll. Not sure how big your doorways are, but if you can use 2 or 3 dollies, that’s what I would recommend. Just make sure that you secure the load with ratcheting straps not just rope.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
May 23, 2009 | Hobart A200 Stand Mixer
Contact overload for h600 3 phase mixer
I'm a hobar tech and repair these often.The problem is the overload contacts are opening so the motor doesnt burn up.I know the mixer is old and the overload has weakend over time or simply the mixer is being overloaded with too much product.Did you just get this mixer?change the recipe?mixing pizza dough and adding ice?Any new employees if it's in a buisness?
Mar 19, 2009 | Hobart H600 Stand Mixer
Hobart 600 wiring connection
The ground wire attaches to the ground lug under the top.
Mar 16, 2009 | Hobart H600 Stand Mixer
I need to change gear oil in Hobart H600 mixer.
Take the top cover off,where the front screw on the cover goes in that long shft has to be unscrewed,get a funnel and add oil.
Feb 19, 2009 | Hobart H600 Stand Mixer
Hobart H600 Stand Mixer Logo
213 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
