Question about Dryers
The drum will not turn on my Maytag stack dryer. It is about 12 yrs old. It heats up, and the belt looks fine
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
You have to lubricate the pulley bearings,and the contact surfaces and change the friction teflon element on circumferance of drum.
Vitally
Posted on May 15, 2009
Drum not turning or heating up
Is power getting into the machine? If so, is the motor turning? If motor turns, is there a belt stretched that prevents drum from turning.
Mar 20, 2016 | Maytag Epic Z and Performance Series 2000...
Musy clarify problem with maytag dryer. heat is working fine but drum stopped turning is it possibly a belt or something got stuck? i can turn drum by hand
You've almost assuredly got a broken belt. There are so many different ways of disassembling various makes and models of dryers, there is no 'one size fits all' instruction to guide you through it.
Mar 17, 2013 | Maytag Dryers
Washer works fine dryer does nothig
Looks like my Maytag. My dryer belt is broken so doesn't tumble. Check by taking two screws out of tilted panel and look at belt. If it isn't heating probably heat coil. If nothing probably electrical. Maybe door switch is open circuited.
Jan 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
Belt and drum turns but with a thumping sound.
check the idler pulley, it could be broken. Also check the inner side of the belt for a chunk missing.
Oct 03, 2009 | Maytag Dryers
Dryer got very hot and smelled burning..
This is usually a result of a stalling idler pulley or drum, causing a burned spot on the drum drive belt.
The situation will only worsen. The belt is best replaced before it breaks.
Items to pay attention to, when the drum drive belt is replaced, are:
(1) Clean and lube the idler pulley and drum roller shafts.
(2) Confirm that the drum glides will yield additional service life.
(3) Check motor condition and de-lint the blower housing and blower intake pathways.
Sep 07, 2009 | Maytag Dryers
No fire
This link --->click here<--- is the exploded view for your unit. If you look at diagram 4 (gas valve), the first guess would be a faulty igniter (diagram location 12). This is only a guess for no tests have been done to narrow down the faulty component.
If you need assistance, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 01, 2009 | Dryers
Maytag dryer does not turn around inside.
Hello, try reaching in the drum, grabbing ahold of one of the baffles. The drum should have some resistance when trying to turn it, If the drum turns very easily, than your belt is either broken or has fallen off. Provide a model # and I can tell you how to open the front panel. Thanks Dave www.washermd.com
Dec 16, 2008 | Dryers
Lse1000
The hard work is over! The old belt should pull out from the drum area if it is broken. There should be two ends to it now. Get a new belt and put it over the front of the tumbler. You should, (with a flashlight) be able to see where the old belt was running. Get the new belt close to that spot.. I believe your model ran with the smooth side of the belt to the drum.It will not look right to you, but the tensioner passes the belt through the pulley and motor pulley on the grooved side of the belt.Once the belt is on, reassemble the dryer front in reverse of disassembly.
Jun 13, 2008 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
57 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
