Question about Car Audio & Video
I have some ma audio subwoofer and the voice coilies blow up in them two 12 trying to get tech support so i can sent them back. the coil was very thin and burn and when out
    President:
  • 1,348 Answers
Check for dc or clipping in your amplifier.distortion causes a dc component which will burn out the voice coil.if you take a 200 watt woofer and run a 20 watt amp at 20%distortion,the dc can cook the voice coil.
Posted on May 15, 2009
I have 2 MA Audio HK 15 X 2 subs and voice coils are blown. How do I fix them
There is little chance that you can do anything about it. The exact voice coil would have to be identified, the old ones taken out, and replacing them is technically difficult/impossible without the proper tools and experience.
Apr 13, 2016 | MA Audio Car Audio & Video
I need a wirimg diagram for a 1000 watt 4ohm dual voice coil
1 sub just run 1 possitave to the other an only one side to amp same for ground
Nov 10, 2013 | MA Audio MA 1200XL Car Subwoofer
Wire diagram for subwoofers
need more info,what ohm load are spkrs? are they single voice coil or dual? if dual what ohm dual 2 or dual 4? what amp are you planning to use? stereo amp or mono block? if mono block what make and model? what style box are you using,sealed or ported?
Jan 09, 2013 | MA Audio MA 1200XL Car Subwoofer
I need a new voice coil and entire cone and surround replacment for my ma audio 2002 model ma100Xl 10" subwoofer. any Suggestions?
MA does not make a recone kit, and does not repair out-of-warranty equipment.
You have a door stopper i'm afraid.
Thanks for using FixYa!!
Sep 30, 2009 | MA Audio MA 100 XL Car Speaker
Need to know how to repair my voicecoils
If you have removable voice coils, you can take them off and buy new ones, otherwise, the speaker is pretty much hosed. Voice coils require too much precision to be made by hand.
Mar 15, 2009 | MA Audio HK15X2 Car Subwoofer
that subwoofer has dual 4ohm voice coils, if your amp can handle 2 ohms, you would put a wire from the positive (+) on the amp to the positive on both connectors on the sub, then hook the negative (-) on the amp to the negative on both the sub connectors that will be a 2 ohm load on your amp make sure your amp at 2 ohms is not more than 600 watts RMS or 1200 max.
Jan 01, 2009 | MA Audio MA 1200XL Car Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Ma120xe sound horrible
Make sure that you have the subs wired in a 4-ohm series and not a 8-ohm load
Dec 14, 2007 | MA Audio MA 1200XL Car Subwoofer
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
