Question about HP PSC 1350v All-In-One InkJet Printer
Whenever I try to print labels, a lot of times it comes out of perimeter.. but sometimes it comes out correctly.. help please!
I have HP all in one 1350 printer and whenever I try to print lables, a lot of times it comes out of perimeter.. but sometimes it comes out correctly.. any help?
  • jaecho85 May 15, 2009
    okay i'll try that, thank you for your help!
  • HP Master
  • 3,866 Answers
Set the printer to print labels along with the software your using... This happends because the printer resets after the next page so set the printer too..
Thanks rulds2008
Posted on May 15, 2009
Why are my paper margins shifted up when printing?
try reinstalling the printer drivers and firmware.
make sure that the calibration is correct and the test page is printing fine.
try a scan-copy test if its an AIO printer.
if that does not help .. then call 1-877-805-1027 for expert help
Jul 23, 2015 | HP DeskJet F4180 Inkjet Color All-In-One...
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Labels are printing in reverse
Whereas I do not have this same printer, the problem may be in the printer settings.  Go to your printer settings/properties and select printing preferences.  Select the "finishing" tab and look for "mirror" and see if the box is checked.  If checked, un-check it. If the mirror box is not checked there is a software glitch.  In this instance go to the "control panel" and select printers.  Delete the printer.  Download the most recent driver for your Operating System and re-install the software.
Try another label/envelope program: Avery has free downloads,  MS Word has a big listing of address printing, as does most word processors.  Check open source software such as open office.  Except for Word, there are a lot of free software out there.
If that does cure the problem, there could be a defect in the printer firmware.  Might need repairing or replacing.
Hope this helps.
May 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printing on a #10 envelope
Go into your Word Document and print from "Tools" then "Letters and Mailings" and click on Envelopes and Labels. Sometime the perimeter isn't defined and it is on there but it's outside the scope of your envelope, especially if the return address isn't in the correct place also. You may even be able to correct it where you are by decreasing the "window" of your typing space, it's just too large.
Jan 17, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Problems Printing From Web
Download firefox mozilla & print from there ...It will be fine..
Otherwise you can download hp web smarting printing utility to correct web printing...
I will recomment you to print from mozilla
Dec 23, 2007 | HP PSC 2175 All-In-One InkJet Printer
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
Printing accurately
Hi there within the envelopes and labels print function within MS Word you will be able to set the correct label and sizes. If this doesn't work then adjust the margins.
This problem is nothing to do with your printer as you are sending a command to it and the printer is doing what you told it to do. Check the settings first.
Thanks J
Nov 19, 2007 | HP LaserJet 1022n Printer
HP PSC 1350v All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
