Question about Microsoft Xbox 360 Console
Cant connect to xbox live through router
I have a wireless router for my home.  My computer connects wirelessly without problem.  the xbox360 is connected directly to the router, i.e. NOT wirelessly (LAN).  The console will not find a connection if the WAN on the router is password protected.  When I test the network settings it seems to fail a different test each time.  If I leave the network unprotected then the xbox has no problem connecting to xbox live.  How can I fix this so that I can use xboxlive and still have a protected wireless network?
  • Anonymous Nov 07, 2008
    xbox fail on dns when connect through router
  • 59 Answers
Hey stchivo, not entirely sure what's happening.  It might help to know what type of router you have.  I know the new linksys routers have a new security feature by the name of SES or something of the sort.  Make sure that is disabled and that DHCP is enabled.  Also make sure a firewall on the router isn't blocking it.  It might help to have screenshots of your router settings to better evaluate what's happening.
Posted on Oct 16, 2007
My xbox360 does not want to connect to wireless connection,it's been two days now..
Posted on Nov 07, 2008
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here:
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
Make sure you are connected directly to the modem if you are using the usb cord .If you are using the wireless adapter make sure the code u imputed corresponds with your own.
Nov 15, 2010 | Microsoft Xbox 360 Console
Cant grt xbox360 wireless adapter conected to wireless router on pc down stairs
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
The problem could be that the signal is too weak upstairs for the XBox especially if you have a concrete floor between the XBox and the wireless router. Try moving the wireless router around to increase signal strength to the CBox.
The other problem could be the XBox is not configured correctly.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again.
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
I have a Linksys WRT160N, and xbox live wont even connect?
If your only using this router for Xbox Live id Ditch is I had this same router had nothing but Problems heres a link with a list of compatible routers.
Sep 20, 2009 | Linksys WRT160N Wireless Router
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Jun 02, 2009 | Microsoft Wireless Network Adapter Xbox...
The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
How Can I connect a network adapter from my room to downstairs about 20 yards away?
I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
The router downstairs is a TalkTalk modem help me!
Jun 28, 2008 | Computers & Internet
Xbox360 Live
you will need to call tech support for linksys on this one xbox might have diff setup that may need configed
Sep 23, 2007 | Linksys Wireless-N WRT150N Router
Microsoft Xbox 360 Console Logo
429 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
