Question about T-View TView (T606HR) 6" TFT/LCD Monitor w/Dual Mounting&Remote
Tview 718dvpl AV INPUT PROBLEM..NEW INSTALL
I cant switch the input from DVD to AV. I have Dash mounted dvd and rca video to 2nd headrest monitor works, put can't get video input to 1st unit with dvd. it says "no av signal" unit was professionally installed so I have no manual.
JMuskovitz
  • 135 Answers
SOURCE: Back A Car Signal
The speculation on this webpage: http://www.mp3car.com/vbulletin/archive/index.php/t-88625.html makes it sound like it is a trigger to switch the monitor to display a rear-facing camera when you put the car into reverse. You would either wire it to a manual switch (to 12v) or to your reverse lights. Keep in mind, this is not an authoritative answer. Good luck, and let us know if this helps!
Posted on Mar 20, 2007
  • 11 Answers
SOURCE: A/V AND Power wiring diagram
hi on what you have just told us go and get the same cables that you were using in the old car coz this wires are the ones ment for the screen i mean right holms,right jack pins for it . good luck .
Posted on May 11, 2007
GooFyTiS24
  • 33 Answers
SOURCE: no video just a blue screen
i would 1st find a remote for them, that would probley be the easiest way... then 2nd check all your wires and make sure you have the right ones hooked up... but if your getting a blue screen then my guess is you have them hooked up right... so i would start with the remote...
Posted on Aug 10, 2008
SOURCE: Tview t104fdsh overhead monitor plays picture upside down
There should be a section in the set up of the monitor to invert the screen. or maybe a invert button/reset
Posted on Mar 13, 2009
SOURCE: CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Posted on May 15, 2009
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
How do I hook up my little DVD player to my tv?? The DVD player only has red, yellow, and white cords,, where to I plug it in at on the back of the tv and which setting.
New Samsung HDTVs use the GREEN RCA input for the yellow RCA video cable, plug it in there. Select the AV input on the TV. For sound, connect white RCA cable to white RCA input on TV.
Aug 21, 2011 | Samsung 50 in. Plasma TV
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Jul 01, 2010 | T-View TView (DVD1006) In-dash DVD Player...
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
I got dual (forj) headrests the sound works on the one that has the dvd in it but not the one that does not, the rca jacks are hooked up to it, it has speakers in it, does it even have sound?
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
Dec 12, 2009 | Dual Car Audio & Video
Iv hade these forj dvd monitors installed but i can only get sound on the radio
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Walmart dual headrest dvd player has no sound on passenger side
Oct 09, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Car Audio & Video Logo
125 people viewed this question
Top T-View Car Audio & Video Experts
Brandon Berry
Brandon Berry
Dan Apthorp
Are you a T-View Car Audio and Video Expert? Answer questions, earn points and help others
