Question about Bosch Axxis WFL 2060 Front Load Washer
Rubber seal got dirty
How can you keep the rubber seal clean all around?
  • Bosch Master
  • 3,463 Answers
Clean thoroughly with scouring pad and liquid cleaner, you will not get all the marks off,but as long as you get the worst off, it should be o/k.
To keep it from getting any worse, do a 90oC wash with powder in, but without clothes at least once a month, this will help keep it clean.
The problem is initially caused by doing too many low temp washes, so this is why you need to do a hot boil wash periodically.
Please rate my solution.
Thanks.
Posted on May 15, 2009
Dirty spots on washing from Electrolux Inspire washing machine 3 yrs old. Spots of washing powder residue on clothes. I have cleaned out all the gunge around the drum rubber seal and run a quick wash. ...
see the instruction manual go to the section troubleshooting and fix it.
or call the customer service from your company who sell the machine for indicate the chemical better .
God bless you
Jun 19, 2012 | Washing Machines
I had a machine exclusively for my dirty rags and dogs beddings, how can I clean inside with the round rubber around the drum close to the door. I tried vim and vinegar as what miele technician suggested...
Vinegar is what is suggested to clean the mold build up and if it hasnt come clean the only other option is to replace the door seal and defiently leave the door open once seal has been replaced to prevent build up in the future
Jul 26, 2011 | Miele Washing Machines
I have a whirlpool frig that around the doors are getting hot
You may need to check into a new rubber sealent to go around the door - If you are not getting a good seal around the door it will not properly cool , expecially around the door - the way you test this is put a dollar bill on the close of the door - close the door around it - if the dollar falls and the door does not hold it, you need to replace the rubber Gasket (seal) You can find them at Home Depot or Lowes resonably priced... Hope this helps
Nov 03, 2010 | Whirlpool Refrigerators
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer Odors of Mildew
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The rubber on the inside front of the washer ("the door boot") gets very dirty, slimy and is all stained. As I pulled the rubber back to clean it, it was digusting ! It is starting to leave marks on the...
at this point and time the best thing to do is replace the door seal.and then make sure after each wash cycle you dry out or leave the door open somewhat in order to help keep it dry and clean
Jan 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Is there a way to clean rubber seal around the opening?
Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
Apr 29, 2009 | Washing Machines
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Washer
You know, Dealers would tell you any thing just to sound clever.
it needs a service,The reson being,on the back of the drum and under the drum you get bearings, i think 3 of them,they r filld with grease.Just take if for a service or if you can do it ur self,after that you can clean that door rubber with petrol, YES Petrol :).
Hope this helps you...
Sep 08, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Axxis WFL 2060 Front Load Washer Logo
250 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
