Question about Gateway 2520915 Keyboard
Connecting Gateway Keyboard to Dell Laptop with PS/2>USB Adaptor
The PS/2>USB Adaptor I have connected to the laptop shows "Unknown Device" for the keyboard
  • Greg_2007 Nov 16, 2007
    Have two PS/2 Gateway Keyboards 7002737 & 7001211 (people seem to throw them out even though they are solid in construction)
    Both will NOT work on my Toshiba Laptop with a single USB adapter ...
    but for some reason unknown they will function with a Multi PS/2 adapter for mouse & keyboard .... the 7001211 keyboard multikeys will work with the 98 drivers downloaded from Gateway on Vista .. the 7002737 multikeys will not even load ... Gateway seems to make some odd duck keyboards
Does the entire keyboard function with the multi-adapter? I am having the same problem, and i just bought a single ps/2 to usb adapter. If it works, let me know. THanks!
Posted on Apr 11, 2008
Keyboard Not Working
Keyboard could need replacing. Try connecting a USB external keyboard and see if it works. If it works okay, you need to have the laptop keyboard connections checked. Replace the keyboard if connections appear to be okay.
Feb 08, 2014 | Gateway Genuine Nv55s Nv57h Nv75s Nv77h...
Laptop keyboard not typing letters
Even a Panasonic Toughbook can have a defective keyboard.
Try to connect an external PS/2 or USB keyboard.
Make sure the laptop is powered off before connecting a PS/2 keyboard. The USB keyboard can be plugged in at any time.
If the external keyboard works, the cost of a used external keyboard should not exceed $5 bucks.
Once in a blue moon the internal keyboard may be "disconnected" either by accident or maybe on purpose. If this is the case, then reconnecting the keyboard may solve the problem.
Good Luck and Best regards from:
Richard, a Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989
Jan 28, 2014 | Panasonic Computers & Internet
I am wanting to connect a Gateway keyboard to a Dell PC but I need an adapter from female to male usb port. What adapter do I need? Will I need to download any software for this?
amm udont need an adapter, the keyboard once usb will plug right in,, if its circular,means its a ps2 port and you need ps2 to usb. No no drivers needed. Or usb to ps2 ,, depends on your needs, But all Usb are standarad stuff.
May 06, 2011 | Dell Computers & Internet
The USB port on my DELL Latitude C400 does not recognize the mouse
try to use otehr usb ports on your computer. check if the light on the bottom of the mouse lit up. open device manager. under mouse - delete otehr mouse components then restart computer.
Mar 08, 2010 | Dell Latitude C400 Notebook
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
My laptop is dell inspiron 1501 but no work keybord and battery charging but supply line(AC adaptor) is ok.
Hello there. The Inspiron 1510 was released almost 5 years ago. If your system is more than 2 years old, then perhaps you will have to replace the battery. Battery for the most part, will only last 1 to 2 years. As for the battery, try connecting an external USB keyboard. If its working, then you need to replace the laptop's keyboard. Hope this will help.
Mel
Feb 13, 2010 | Dell Inspiron 1501 Notebook
When Gateway Laptop is powered up after shutdown it is necessary to reset the network adaptor using Windows repair process before it will connect to the web. Can I replace the adaptor and if not can I buy...
You will find the driver is corrupted download the network driver and reinstall is first choice.
You may delete the driver in system properties and hardware then let windows reinstall the network driver.
Yes you may also install the USB network adaptor.
If the wireless device inside the laptop is Intel download from the Intel website.
Remove the plate from the bottom of laptop to obtain the brand and model.
Hope this helps you.
PS. system defragment should be done once a week
Oct 23, 2009 | Gateway Computers & Internet
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Aug 24, 2009 | Dell SK8110 Keyboard
Belkin wireless keyboard receiver won't work with my laptop
Yes and no...
"Wireless enabled" means you do not need a separate adapter to connect to a wireless NETWORK or computer, not a peripheral device.
I assume the two connectors are PS/2- plugs - one pink, the other one green. What you need is a PS/2- -to-USB adapter that should have come with your keyboard. PS/2-in, USB-out, either with or without the cables (see picture)
Dec 18, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Keyboard to Laptop connectors
go to Amazon.com, and look up ps/2 (which is the official name for the connector type normal keyboards have) to usb adapter, and you should find a little green thing that adapts your keyboard to usb. Make sure that the usb is a male end, and the ps/2 is a female end, or you've got the wrong one.
However, before you do that, I want to let you know that I just did the same thing, and I cannot get my Gateway keyboard to work on my HP laptop through usb. I have no idea why, and I am currently trying to find a solution. So I wouldn't suggest buying it until you know how to fix it. If you figure it out let me know.
Dec 04, 2007 | Gateway 2520915 Keyboard
Gateway 2520915 Keyboard Logo
444 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
