Question about Polaroid TDX-03211C LCD TV
No sound with HDMI connection.
Polaroid 32" LDC television. No sound with HDMI connection to cable box. Works fine with coax connection.
    Genius:
  • 1,148 Answers
COULD BE A BAD HDMI,,CHECK TO SEE IF ITS TURNED ON ON THE CABLE BOX
Posted on May 15, 2009
How do I cable this connection please?
It depends what input connection the second TV has available. You cannot directly daisy chain HDMI cable from Apple TV to the two TVs assuming both have HDMI input. But you can purchase an HDMI 1x2 splitter and connect the 3 up provided the 2nd TV also has HDMI. The challenge maybe the distance you can have between the two TVs. Max is 15 meter but you could cascade 2 units to create longer distances.
http://www.ebay.com/itm/HDMI-Splitter-Box-High-Speed-Full-HD-1X4-4-Port-Hub-Audio-Video-1080p-Amplifier-/191120909726#ht_2675wt_1337
Apr 28, 2014 | Televison & Video
Will not receive incoming cable signal
You didn't mention how you are getting your cable, but will touch on it briefly. Please clarify if you need more information.
Your cable comes in through the wall, and it should goto a converter box / receiver box. The output of this box then is connected to your TV via either HDMI, component video, audio visual connections (RCA), or perhaps the cable coax connector. Sometimes, the cable box will connect via a DVI port, but those are relatively uncommon. Almost *all* modern cable systems have gone to a digital format, which requires a converter box. There are very few, if any, cable standards that are still analog (which could be tuned by your tv at one time). If unsure, contact your cable company to find out exactly which you have, and if a converter box will be required.
You need to setup your tv to look at whatever input the cable box is using, or tell it to look for a signal on the cable coax connector. Make sure the cable box is on before you try to set it up, or you may waste your valuable time.
Feb 13, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a hitachi 42hds52 tv; i have my cable box connected to it by both hdmi and coax cable. the coax is fine, but the hdmi is not working
Try the anothe HDMI input or cable or try HDMI from another source (DVD) you could also try component in(Ry,Gy and By) to see if that works.you need first to determine if it's a cable box, cable or TV issue.
Oct 11, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Jul 29, 2008 | Olevia LT32HVM 32 in. LCD Television
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
No sound
go to the setting sound page in the manual page 28 follow the instructions and check if the speakers have been shut off in the set if not the main board must be replaced.
Dec 23, 2007 | Polaroid FLM-3201 Television
No sound
Are you using a set of sound wires in addition to the HDMI cable? - HDMI only carries the HD Video and no audio, so you still need either a digital or audio cable to pass the audio to the set.
Aug 30, 2007 | Polaroid FLM-2632 Television
Polaroid TDX-03211C LCD TV Logo
366 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
