Pls advise soon, how to format my laptop, because it hangs all the time, and stucks, what can i do
SOURCE: about laptop ethernet...
First figure out whether your hardware is ok and driver is installed properly.
In Windows XP, click Start , right-click My Computer , and select Properties .
Thanks
If the network adapter icon is listed without problems, and the connections, service, and modem are working properly, then refresh the networking drivers.
Iqbal
SOURCE: lan driver
A simple Google search resulted in this page (amongst others):
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-1715XCDS/download/page,sh,30795,221,19,.html
Otherwise find out what LAN card you have installed and search the Internet using Google and this string:
(Brand name) (model number) +driver
and you should find the driver that you are looking for.
To identify your LAN card:
RIGHT click on My Computer and select Device Manager. Your Lan card should be listed there.
Good Luck.
SOURCE: PLS HELP MY ACER LAPTOP
My acer laptop the problem is i have horizontol and vertical colourered lines all over the screen with two large black spots
SOURCE: Administrator Password for BIOS lost
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: laptop got stuck in a black screen with cursor
Try following
method to get rid of Black screen problem.
1) TAKE OUT
YOUR LAPTOP BATTERY
2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
That will drain
any static electricity that has built up on your laptop system board.
