Question about Remington R-1000 Electric Shaver
Remington R-1000 battery replacement
I need new batteries for my Remington R-1000 shaver. The ''manual'' tells how to take the shaver apart to get to the batteries, but it really doesn't. Does anyone know how to take this shaver apart?
I guess by now you have either thrown out the shaver or found out how to take the cover off.
The secret is to remove the bottom cover plate (Cap) as described in the manual. There is a small slot at the back of the charging cord recess (see photo) that allows you to pop it off with a small, flat blade screwdriver. There are 2 screws under the cap, and 2 more at the top under the trimmer assembly, which is removed as described in the manual (the manual states there are only 3 screws holding the cover).
The batteries are AA NiMH, 1800 mAh capacity, which I hope to get at The Source (used to be Radio Shack in Canada).
When removing the batteries, make sure to carefully pry off the heat sensor which is attached to one battery with a dab of silicone (and which must be reattached later).
I have attached a few photos to show the slot in the cap, and the battery wire colours when you are reconnecting new batteries.
MikeD
Posted on Mar 03, 2011
  • Bill C. Riemers
    Bill C. Riemers Jul 31, 2013
    Your pictures did not help in the least. I could not find a way to pry that bottom cap off. I finally ended up pulling on the back until it bent enough to pop the cap off with the pressure.
  • Bill C. Riemers
    Your picture did not help in the least. I could not figure out how to pry the bottom cap off. I finally ended up bending the back cover out of place until the pressure popped the cover. It damaged the plastic abit, but it didn't break. Now off to buy some batteries. My wife offered to solder them for me since my hands shake too much for that.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Need a replacement battery for remington ES1000 electric shaver and blades
Unfortunately, blades for this model were discontinued several years ago by the manufacturer and are now impossible to find now.
Batteries can be purchased from shaveroutlet.com. You will need two. See link below
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
Sep 22, 2011 | Remington ES-1000 Electric Shaver
I have a Remington Microscreen2 shaver. The rechargeable battery no longer will take a charge and I need to replace it. The problem is that I can find no instructions for removing the battery from the...
You will find the correct battery type at shaveroutlet.com. See link below. You will need two
To replace the batteries, start by removing the foils and cutters. Then, gently pry off the rubberized grip on the front. This will reveal two screws at the bottom. Remove screws. Then gently pry off the silver metal plate that is at the top of the shaver. You can then gently pry the front and back case apart.
Inside, you will find a circuit board with the batteries attached. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 10, 2011 | Remington MicroScreen 2-300 Electric...
I need find battery
You will find the correct battery type for model ES-1000 at shaveroutlet.com. See link below. You will need two
Jan 24, 2011 | Remington ES-1000 Electric Shaver
How do you remove the battery from a Remington Dual Foil 30 Shaver?
There are two screws on the back just under where the cutter fits on. Remve shaver head then remove screws and you can then gently pry the front and back apart from the top.
If you need replacement batteries, you will find them at shaveroutlet.com. See link below. You will need two
Dec 20, 2010 | Remington Health & Beauty
Will not start..?
Battery is probably dead. Replacing batteries is possible but you will tear up the shaver getting it apart as the case is glued together. I suggest purchasing a lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Nov 28, 2010 | Remington Titanium MicroScreen MS3-2700...
I need to know how to change the battery. Can you send a manuel.
Printed instructions for battery replacement are not provided by the manufacturer.
You will find batteries for model ES-1000 at shaveroutlet.com. See link below (you will need 2 batteries)
To open up the shaver, gently pry off the rubberized grip on the front with a small flat screwdriver or similar. This will reveal 2 screws at the bottom. Remove the screws and the flat plate under the cutters that clips on there. You can then gently pry apart the two halves.
You can then access the batteries, remove the old ones and solder the new ones in place
Oct 18, 2010 | Remington ES-1000 Electric Shaver
Rechardable battery . can you tell me how to take apart a remington shaver. to change the batterys. i have MODEL NO, MS2-300 RS4843. YOURS D.Sweeney.
First, remove the foil and cutters. You will then need to gently pry off the rubberized front cover with a small flat screwdriver or similar object. You will then be able to access and remove the two screws at the bottom. You will then need to pop the case apart by carefully inserting a flat screwdriver at the bottom between the AC port and the case. Once you pop it apart you will need to remove the metal clip at the top that so that the case can be fully seperated.
You will then be able to see the batteries.
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries at shaveroutlet.com. See link below. You will need two batteries.
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If this is not something you can do yourself, you might want to consider one of the items below which will give you and easier fix
http://shaveroutlet.com/remington-ms2370-lower-unit-p-208.html
http://shaveroutlet.com/remington-ms2100-lower-unit-p-209.html
Apr 24, 2010 | Health & Beauty
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Replacing the battery
Download the user manual - it has battery removal instructions ----
http://safemanuals.com/user-guide-instructions-owner-manual/REMINGTON/MS3-1000
Nov 28, 2007 | Remington MicroScreen 3-3000 Electric...
Remington R-1000 Electric Shaver Logo
703 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
