Question about HP DeskJet F380 All-In-One Printer
Can not print
Can't get my hp380 all in one printer to print, What usb port should I be using front? back? which one theres plenty
  • e_reyna82 May 15, 2009
    my computer doesn't show all of the graphics, what is wrong
THE PRINTER CAN NOT PRINTING
Posted on May 17, 2009
    Sergeant:
  • 186 Answers
You can use both. But remember if ur printer is USb 2.0 then it would not work properly on USb 1.1 Port.
Posted on May 15, 2009
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
My Canon Pixma ip6000d isn't printing any images or text. There is plenty of black ink, I ran the tests for alignment and nozzle check. The paper feeds through fine and it sounds and acts as tho
Did you try a test print. Most printers have a option to set the ink color, this is done when your computer asks you if you want to print. Look for an options tab and search for ink color options pick black only and try a test print. The test print is done on printer set up. If all else fails try the manual it usually has a troubleshoot section. Oh yes make sure you have the correct usb port some are configured at a lower level ( mine has 2 different ones a 2.0 and a 3.0 the 3.0 is blue when you look inside of it) my 2.0 port wouldn't set up my printer I had to use the 3.0 port. Hope it helps you some!
Feb 15, 2013 | Canon Pixma iP6000D InkJet Photo Printer
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
I can't print from the computer. when I toubleshoot it says i'm not cnnected
Try a different cable and or a different usb port. If you are connecting to the usb ports in the front of your computer, try one in the back. Many of the older computers front usb ports were never connected.
Make sure your printer is turned on.
May 05, 2011 | HP Officejet 5610 All-In-One InkJet...
Can't get it to print from usb port
the usb port might be dead.... try LPT or DB9 cable . if you reallly need the USB then you have to change the Main logic board
Jan 13, 2010 | Zebra LP 2844 Thermal Printer
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Not printing from my laptop
If you have inserted the USB cable into the slot on the front of the printer, it will not print from the computer. That slot is for direct printing from a digital camera. You need to insert the USB cable into the port on the back/side of the printer. The port is almost square in shape, and should receive the end of the USB cable that is square with two rounded corners. The other end of the USB cable, much more rectangular, goes into the USB slot on your computer.
Apr 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Connecting USB cannon mp610 printer to computer
You need USB A-B cable and use the USB jack lying on the back-right corner of the printer (not the front one - that is for connecting cameras).
Sep 02, 2008 | Zebra LP 2844 Thermal Printer
Canon i850
Hello  btfsplk,
Me is Vikram Kumar Thumu from India-Hyderabad. I have seen your message and issue on this issue. I would like to provide my suggestions on this issue.
Generally, this issue could happen if the Port selected that is Printer Properties  is not same as the Port connected to the Computer or Notebook, if this is the case the Printer starts Printing Blank pages from Computer . The issue could also happen if the Printer software is corrupted.
To resolve the issue I recommend you to check and try out below options:
1. try to restart the Print Spooler.
2. Make sure that you selected the correct port in the Ports tab of the Printer Properties.
Example: If your Printer uses USB cable to connect the Computer, then make sure that it is USB001 or USB002 is selected in the Ports tab of Printer properties.
Note:  Make sure that Printer is connected to the USB ports of Computer at Rear End and not in front end. Since, front end USB ports in Desktop Computer are meant for USB flash Drive or other USB devices and not for connecting Printers.
Well, I need much more information of your computer so that I can help you further steps of troubleshooting.
So please let me know below information:
1. Version of Operating System that you are using on your Computer.
2. Please let me know the Printer Model number and Serial number along with Manufacturer.
3. Did you receive any other error messages on this issue?
4. Please let me know cable type ( USB/Parallel) that you are using to connect Printer to the Computer.
Please mail the information at thumuvikram@rediffmail.com, I'll be glad to help you with further information on this issue.
Bye .
Oct 15, 2007 | Canon i850 InkJet Photo Printer
HP DeskJet F380 All-In-One Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
