I have installed the BW900 with a Zoom Switch and a HSL10. Here's the problem: when the zoom switch is set to computer (for transcribing dictation) the HSL10 lifts the handset, therefore the phone rings through as busy. How do I listen to dictation on the computer without the HSL10 lifting the receiver? Thanks so much!
    Sergeant:
  • 296 Answers
Hi
chek these links for your required information..u will b helpfull
http://speechrecsolutions.com/zoomswitch.htm
http://speechrecsolutions.com/microphones_sennheiser.htm#hsl10lifter
thankyou.
Posted on May 15, 2009
Replacement of zoom switch assembly
Is the auto zoom set. Anyways, too hard to answer without the camera model
Nov 26, 2014 | Video Cameras
Red light flashing
The lifter is a piece of junk. The red light means its time to get another. If the lifter will not lift the handset then it's time to get another - the best thing is do not get one to start!
Nov 11, 2013 | Sennheiser HSL10 Headset Lifter - BW900...
Zoom button stuck on full in zoom
Possible that the zoom switch is short or struck in action where by the zoom has gone to the extreme end. Wriggle the switch after the cam is switched off and see if it returns. If not the unit must be opened to check for the switch failure or possible motor failure, drive circuit or a mechanical jamming.
Nov 30, 2011 | Canon MVX200i Mini DV Digital Camcorder
What would cause a sony dcr trv120 zoom button not
There is control switch block that has zoom/wide switch along with play, rewind, forward, stop, pause buttons and this switch block flip up and down while ejecting/ load tape in camcorder, this will be replaced as zoom/wide switch got defective and sending continues command of zoom to system control chip.
Let me know if you need part number of switch block control for DCR-TRV120
Jul 27, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
My IPhone screen is magnified and it won't go back
If you tap it twice with three fingers it will zoom the screen out and if you do it again it will zoom it in .... after go to setting - General - accessibilty - zoom - turn off zoom
And It Will Never Happen Again
Jun 27, 2010 | Apple iPhone Smartphone
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Canon XM2
You might have bad contact in zoom switch unit or a short in zoom switch. The switch assembly is replaced for the remedy.
Mar 13, 2007 | Canon XM2 Mini DV Digital Camcorder
Screen automatocally switches between zoom settings
Go into the menu and set the 4:3 default either on or off i think it should be off
Feb 24, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
jasbo
jasbo
