Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water is not coming out of dispensor in the door. Still produces
You can here the click of the motor when you push the lever for the ice
  • GE Master
  • 4,654 Answers
On the back of your refrigerator there are 2 water control valves. While pressing the water dispenser switch in front you should get 120 volt to the coil that controls water flow to dispenser. Can you check that first. I also have the repair manual for the model listed above your post but I am never sure that is correct. So I need you to confirm that number again so as not to get on the wrong path.
TFX27PRBWW correcct? Now also the feed to the water valve can be restricted. Let me know what is the model number for sure and I will leave you with some things to check and do. You also are welcome to contact me direct seabreezehvac@yahoo.com
site below enter model number, we offer free assistance and help,
http://servicepartstec.blogspot.com/
place model number in model search feature, check refrigerator for number again,
aa3a741.jpg Thanks, Sea Breeze
Posted on May 15, 2009
  • John Tripp
    John Tripp May 16, 2009
    OK I got your email and that is possible to be a reason. I have a service manul for the Artica Profile check your email will be sending you a copy. Sea Breeze
  • John Tripp
    Shawn, Have you checked the water valve on rear to see if that side that feeds the cold water to dispenser is working. You said it may have water frozen. That may be possible. It also maybe frozen in the line at the dispenser door. Look inside the fresh food compartment and pull the bottom tray away so you expose the cold water reservoir. Check temperature there in that area. If things look good there we need to go to the back and check the water valve that opens to push water through to dispenser front.
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Water dispenser will not work Just tried to get water from the dispenser.I heard a clicking when I pushed the lever in with a glass,but no water.I loosened the water line at the compression fitting at...
The ice works off of a different solenoid than the water dispensor . So , I would suggest this action : At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jan 28, 2010 | Hotpoint Refrigerators
Fridge makes a clicking sound, stops if lever for ice/water press
this model has a p c control in the back and the clicking sound is common when its failing . Pt # wr55x10656 ) there is a up date kit for this frig . ck on the kit before replacing the board as its included in the kit . hope this helped ****
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
No water through door - PSS25MGMA WW - replaced water bracket and valve assembly - GE Profile Artica
Since you have already replaced the water inlet valve , at the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is also a water dispensor heater kit , pt # WR49X10173 , which comes with installation instructions .
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
GE REFRIGERATOR'S ICE DISPENSOR PROBLEM
CAN U TELL ME WHAT YOU DID TO FIX THIS PROBLEM. I AM NOW EXPERIENCING THAT EXACT PROB!
Nov 09, 2009 | GE Refrigerators
Whirlpool Gold Model GD25SFXHS03 exterior ice lever not working
Your problem is probably a broken plastic switch bracket . Pt # 2180226 . To access , use a butter knife between the dispensor grill and the lower portion of the dispensor cover . FIRST , remove the cover on the top freezer hinge , and disconnect the plug there . This removes all power to the door . Insert the knife about 1 " from the side , and push down and inward , to push the plastic tab of the cover , outward . Do the same for the other side . Lift upward to slip the top tabs free of the mount . Disconnect the plug to the dispensor cover , and remove the cover . The white piece with the 2 switches , probably has a short plastic stub , broken off which holds the ice dispensor switch . Looks like maybe 4 small screws , hold the switch bracket on . Transfer the switches carefully ,because you are working with plastic . When reinstalling the dispensor cover , after attaching the receptical , slip the top portion of the cover in place , and pop the bottom to latch the lower clips .
Aug 30, 2009 | Whirlpool Refrigerators
Water and Ice Dispensors say engaged
Bad switch, you will need to replace the switch if it is under warranty call your warranty provider if it is not then go to repairclinic.com and order the part for your system
Feb 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water at the door
If the solenoid valve doesn't click anymore then it's either bad or not activating anymore. Check that the switch behind the water lever is not broken or has fallen loose inside the door panel. You may be able to put a finger up there and try to push it without using just the lever. (sometimes slamming glasses into that lever over time breaks the switch attaching pins causing the switch to fall off inside). Take the front panel off and visually check that switch itself to see if it is still being held in place. Activate it by hand (not the lever method) and see if that water solenoid valve clicks again and water flows. If you have no water to both the Ice Maker and door dispensor at all (clogged filter?) check the main water line for clogs/debris, etc. If you are making ice still then water is at least getting to the ice maker and that means only the door water valve or switch is bad. The link below may help you "see" inside with the different diagrams, etc. http://www.partselect.com/MultiModels.aspx?ModelNum=GSL25JFP&searchTerm=&RefineSearch=0
Nov 20, 2006 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
