Question about Jenn-Air JED8230 Electric Cooktop
Hot plates are very slow to heat
We have a countertop range (Jenn Air) with 4 hot plates. The plates are solid (i.e.not a coil). They heat very slowly.
    President:
  • 1,865 Answers
Did this problem always exist, or did it gradually occur. If this is a new problem, then I would suggest that there is a bad connection someplace in the circuit. I would troubleshoot this using a voltmeter and start from the circuit breaker, and look for voltage drops across connection points (including the switches to turn on the hot plates)
If this was always a problem, check to be sure that your voltage supply matches that of the unit requirements
Posted on May 15, 2009
Jenn-air fan works à short time then shuts off. Is there a capasitor that may be over heating or a bad switch
It sounds like it is getting to hot and going out on thermal. The probable culprit is the bearings are failing.
Jan 28, 2015 | Jenn-Air Cooktops
How to wire element
check the link it might help. Usually the Red or Blacks are Hot or Line the Tan and yellows are the heat range Lines for the inner and outer coil 03 Wiring Information Parts for Jenn Air JEC8430ADS
Dec 04, 2013 | Maytag MEC5430 Electric Cooktop
After fan is on for awhile the motoe feels hot to the touch..Why??
That is because small motors like this are very inefficient.
Almost everything in nature that has inefficiency throws off energy as heat.
The motor is probably throwing off 100 watts of waste heat total, which compares to the heat of a 100 Watt light bulb, so getting hot is not surprising.
Dec 15, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
I just need to know the cutout dimensions for jenn air smoothtop
i asume that you want to cut your counter to drop the hot plate in turn your plate upside down measure about 1inch smaller than the dimention of the plate is should work fine thanks from gilles
Mar 15, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Cooktop will not get hot
wire conections to ct from house wiring may be loose check conectors
Dec 24, 2008 | Jenn-Air JED8430 Electric Cooktop
Will burner get too hot
Hello Pinewood7. The issue here is concern from what you have heard. Don't worry! All you are doing is boiling water. The system will allow constant heat for what you are doing. Use this as a test. Put your largest pot on the top full of water and set on high. Attach your thermometer to the side and see what happens. I know several people who use these tops for canning with excellent results. My sister in law has had yours for years and not an issue with jams. Hope this helps with your concerns.
Aug 09, 2008 | Jenn-Air Expressions AR141 Electric...
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
66 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
