Goldstar model number wg1205r AIR CONDITIONER, NOT COOLING
Goldstar model number wg1205r not cooling. motor running, but no cool air coming out of unit.
  • 78 Answers
Thermal relay is not functioning , u need service technician
Posted on May 17, 2009
On Goldstar WG6000R window air conditioner, what is the difference between "cool" and "dry" settings?
Dry means that the air is dehumidified, not heated or cooled. Cool means the temperature is reduced.
Jul 03, 2017 | Goldstar Heating & Cooling
HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
Put a filter on it please.
Jul 10, 2011 | Goldstar Heating & Cooling
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
Jun 22, 2011 | Goldstar R5208 Air Conditioner
My air conditionner is not working properly. It sends cool aire keep getting code E3 What can I do to fix it Tks
micheline, according to the LG Owner's Manual for the Model Number you listed, there is no LED display on the casement window unit (please see the Owner's Manual link below). How are you getting an E3 error code? Or by chance, did you list the wrong model number? Even Goldstar, that is made by LG, doesn't show your model number.
Please advise. Thanks.
Jun 01, 2011 | Goldstar LG LC1200 Casement Air...
Does not cool room.
Goldstar WG5000 air conditioners use an R22 refrigerant. A charge kit containing the gauges needed to properly fill the unit, and the refrigerant tank/cartridge can be purchased to fill the air conditioner.
Jun 03, 2010 | Goldstar WG5000 Air Conditioner
Unit turns on no cool air comes out even when setting is on high
1 Please remove th back cover and check if the cooling pipes are getting cool when the air conditioner runs. If there is no cooling /moisture deposit on the pipes it means there is no gas in the air conditioner. Get that checked up. Refill the gas after getting checked up that there is no leakage.
May 31, 2010 | Goldstar GW-HD5000 Window Air Conditioner
Unit overheating and blowing fuses
Low gas pressur causing the unit to overwork/heat, water trap coolant service port blocked. Some machines need 1/2 liter of water pouerd into a reservoir on the rear to aid cooling the heat exchanger, if this is dry it will overheat. cheakc the filters if it has any.
Jul 28, 2009 | Goldstar GW-HD5000 Window Air Conditioner
I have a Goldstar window unit 6500 BTU it has Cool, Fan, and Dry
in all honesty, it's a ridiculous gimmick. the system still runs the same as it would when you are using the A/C, however in Dry Mode there is a small heater in the unit which runs also, to prevent the system from lowering your room's air temp. a/c's always dehumidify air anyway, so basically dry mode is like running a/c and heat at the same time. $$$$$$.
Jun 11, 2009 | Goldstar Heating & Cooling
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Cooling motor shuts on and off...
No it is not normal. You might have a bad capicator to the motor.
Is your unit still under Warranty? If so. Call the service center.
May 19, 2008 | Goldstar GW-HD5000 Window Air Conditioner
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
