Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Error message Battery is charged and when I take a photo the shutter half way opens then camera says ERR 99 and no photo is taken.
This is pretty common with the 300D.  There is a pin on which the secondary (AF) mirror pivots.  It looks like Canon didn't used the right, or enough glue to hold the pin to the mirror box assembly.  There are a couple of sites that show sort of how to repair it.  I'm working on fixing mine right now, but have some other issues.  To do this properly yourself, you will need jewlers screwdrivers, a good soldering iron, tweezers, and some glue (I used super glue).
I chose to do the repair because I've got a degree in electrical engineering, experience with micro-electronics, and have more time than money.  I did manage to break the flex circuit that goes to the flash board, which is the source of my woes now.
Posted on Oct 29, 2007
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
Canon error 99
.1. Turn off the camera.
camera body.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Codee error 99 ??
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
you do the following:
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
Hope this helps !!!
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 appears in pattern, every time
Not sure about the pattern of errors, but the advice for error 99 diagnosis is to try the following diagnosis steps to isolate the cause of the issue:-
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Rebel XT EOS Every time i take a pic I get an Err 99. I have taken the battery out and memory card for 5 Min. If i do that I can take about 5 or 6 pics before I get that message again. What...
Try the following diagnosis steps: -
Error 99
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
Jun 28, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
