Question about MotorGuide Electrical Supplies
Moterguide lazer 11 62rf keeps turning until it strip the rack
2 Suggested Answers
  • 244 Answers
SOURCE: Liftmaster rack keeps stripping
what do you mean by rack. do you mean fears. do you have right sprigs on door, is door balanced. lift half way and let go (Disconnected by arm). It should stay put or go slowly up or down. If not, springs are bad, I put a 1/4 hp on 18' wood door. lasted 27 years so far. H/p not the problem.
Posted on Jan 15, 2009
Top roller screw hole stripped
1)make certain all is clean and very dry
2)apply gorilla glue into stripped plastic hole and insert screw.
3)rig something up to keep it from moving for 6 hours or so
careful gorilla has a nasty habbit of pretty much destroying clothes and staining skin so be carefull. don't get carried away when applying it and maybe set down a disposable rag to catch drips.
but it is very permanent. Its what I would do
good luck
Nov 27, 2013 | Frigidaire Dishwashers
Liftmaster garage rack won't return/open. It gets stuck about 1ft from the closed position. I thought the rack was stripped but it seems fine. The motor is really loud. When I press the button again the...
It sounds like something needs lubrication badly or the track is not aligned properly with the door and it is binding. It is also possible the limit settings are way off. Sorry I cannot offer more help.
Oct 20, 2013 | liftmaster Chamberlain Garage Door Opener...
How do i reset the drum counter on a brothere hl7050 lazer printer keep gettinjg the mnessage change drum soon even after i have changed the drum Thx DAz
Here's the solution:
  1. Turn on the printer. Wait for the data light to turn off.
  2. Hold down the "Go" and "+" buttons until the LCD panel displays "RESET COMPONENT LIFE."
  3. Use the "+" and "-" keys to select the drum unit and reset it.
Hope this helps!
Mar 02, 2011 | Brother HL 7050 Laser Printer
What disc do i buy lazer disc cleaner dvd player or just a regular lazer disc cleaner
you need to purchase a lazer disc cleaner it looks and works just like a normal dvd disc but it has brushes on it that when put through the player brushes the dust of the laser lens this needs to be done on a regular bases to keep your lazer working to its optimum level and hense fixing your problem...
Dec 15, 2010 | Nintendo Wii Console
I have a proton pds-2302, serial # pd230250022248. Purchased in 2006. Had been working until this year (2010). When I inserted a disc, nothing happened. I heard some whirling sounds and had difficulty...
as with all dvd type machines the lazer builds up dust and debree on the lazer lens this makes it harder for the lazer to read the incripted information on the disc. much like a torch bean being covered with a cloth the fix is simple you need to purchase a lazer disc cleaner it looks and works just like a normal dvd disc but it has brushes on it that when put through the player brushes the dust of the laser lens this needs to be done on a regular bases to keep your lazer working to its optimum level and hense fixing your problem.
best of luck
merry christmas
and please remeber to rank this advice as to how well it help you.
Dec 02, 2010 | Televison & Video
My phillips HTS3090 system keeps saying BAD DISC
for some reason the unit is not happy with the disc have you tried running a lazer cleaner through it? although i wonder if that will work as the words bad disc does seem to mean a lazer read problem but then it can only be either a dirty lazer or the lazer is miss aligned withch means it need s a pro service .... try cleaning the laser
Jul 03, 2010 | Televison & Video
Will not load game
take it apart (will need a sucrity screw driver) and clean the hard drive.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
Stripped rack for elevation adjustment
Possibly from Orion. Call them:
http://www.telescope.com/control/main/
Aug 30, 2009 | Orion Optics
Oven with an attitude
Check the lineator actuator motor. If you remove the top cover there should be a strip of metal stuck on the cover to put pressure on the gear to keep it from free wheeling down. These is a tiny button/nipple that sits in the hole in the top of the gear shaft. Lose it and you're sunk. Work with good light and watch the grease. Good luck
Feb 27, 2009 | Baxter Ovens
Mar 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Electrical Supplies Logo
122 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
