Question about Gateway MX8711 Notebook
THE STEM WHERE YOU PLUG IN FOR CHARGING BROKE OFF
THE STEM WHERE THE PLUG GOES IN TO ATTACH IT FOR CHARGING BROKE OFF INSIDE THE COMPUTER.IT HAS NEVER CONNECTED CORRECTLY-WHICH IS MY FAULT FOR NOT TAKING CARE OF IT WHEN I FIRST PURCHASED IT,BUT ANYWAY, IT IS ONLY 5 MONTHS OLD AND GATEWAY IS SAYING "I" DID SOMETHING!!! ANYONE ELSE WITH THIS PROBLEM?
  • Gateway Master
  • 3,866 Answers
Well I can tell you alot of people had these problems but what you can to is use a small tweezer to try to pull it out and then you can buy a replacement at www.frys.com they will ship it to you if your out of state. So there has been many people on here with the same issues its these things are verry delicate and need TLC each and every time you use them. Thanks Rulds2008
Asker only please Rate others please hold your rating until we can figure out who is giving me unwanted TFT's Thanks Rulds2008
Posted on May 15, 2009
Will not drain and little thingy popped out
That thing that broke is the float. It supposed be attached to an arm that shuts off the water when the tub get full. Did ya just replace the garbage disposal? If so somebody forgot to knock out the plug for the drain hose. oopzy. Food screen clogged? Ya might need to get down in the impeller and see if a bone or piece of glass has gotten into it. have you seen this video?
Jan 04, 2013 | Dishwashers
The charge plug isn't connecting withe the stem
The DC jack in the laptop has bad connections, or the plug needs to be replaced. However to do that the computer must be dismantled down to the motherboard level to do the repairs, if you are handy with a soldering iron that is a added plus.
Apr 09, 2012 | Toshiba Satellite L505-S5966 Notebook
It was overalled two months back but now it is smoking and plug nunber one and two get wet with oil.
There is deffinatly a problem inside the motor, either a faulty valve stem seal/guide or maybe they broke a ring whilst assembeling the sub assembly.
Feb 10, 2011 | 1987 Volkswagen GTI
I was trying to plug in my speaker and I thought that the plug in the front was a speaker outlet but it was not! Yes I know now it was the headset plug, well my plug in broke off in there, what can I do?
push the broken plug out with a pin from the inside and get a new plug from an electronics parts store and re attach it to the wires of the speakers
Jan 21, 2011 | Dell Audio Players & Recorders
I have an acer aspire one netbook...the part wherre the power cord goes into the computer,that stem broke completely off and I would like to know how much it would cause to have that part repaired.
to have a new plug put in usually costs around 50 bucks, but if it's still under warranty then yake it to Best-buy or Fry's. They both have specific procedures for warranty work, and plugs like this are an extremely common event, so they would know exactly what to do to it.
Dec 16, 2010 | Acer Computers & Internet
Rear turn signal
the stem goes through the body - and has a nut on the other end. You need to find the two wires coming out this hollow nut, trace them to the connectors (undoing any clips that hold them as you go along the wire) and pull these two connectors apart. Then use a spanner (no room for a socket) to undo the nut on the indicator - pull out the indicator and its wire from the body.
Fitting the new indicator requires sending the wires back to the connector, (put the nut on the wire after it goes through the body and tighten it a little on the indicator - you must do this before you connect the wire or it is impossible to attach the nut) Then fully tighten the indicator and make sure it is straight - then test for proper operation of the indicator.
reattaching the clips that keep the wiring out of harms way
Jan 24, 2010 | 1996 kawasaki VN 800 Vulcan Classic
I have a 67 schwinn typhoon and as i tried to pull the head set apart the bolt runing down from the top of the stem broke and the big nut near the frame seams stuck i have now left it soaking with wd40...
cool bike,if the stem bolt broke and the stem is still stuck the wedge in the stem may still be locked take a long bolt or a punch insert it into the stem bolt hole and tap it a few times dont slam it as far as the headset goes your local schwinn dealer should have rhope this helpseplacement parts replace it all cups bearings all of it
Nov 24, 2009 | Cycling
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Thermostat install for 1989 Maxima
it goes inside of the housing unit. but when you put the housing unit on, the stem should be pointing to the engine
Dec 02, 2008 | 1989 Nissan Maxima
Nx6110 laptop ac power broken
you cant put it back in its broke and needs replacincing with a new one.you can if you feel confident enough desolder the the adapter and connect the power directly but not advisable.
Oct 22, 2008 | HP Compaq nx6110 Notebook
Gateway MX8711 Notebook Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
