Question about Ricoh Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Our Savin 4035Esp Copy/Scanner/Printer needed toner. We replaced the toner, it seemed like it was fool proof. We turned unit back on, it detected a paper jam. We couldn't find the paper jam. We rebooted the unit and now we are getting "Funciontal Problem - Functional Probelm with the machine. Turn main power switch off then on. SC863." We turned the system off and found the paper jam and cleared it by turning the green knobs, we didn't need any force or tools. We rebooted the machine and get the same message. We turned the machine off and unplugged it and still get the same message when we turn it on. Is there anything I can do to fix this, like a master reset or something? Or if a part needs replacing, is this something someone who is comfortable repairing computers may be able to tackle?
  • email241 May 15, 2009
    swan34...Thank you for your quick reply. In fact, I was signing back in to update my problem. The SC 863 error is gone after one last attempt at a reboot, the system detected the front door wasn't fully closed, I closed it and it booted just fine. BUT....when we attempt to print or copy, the machine starts to act like it is going to copy or print, it even pulls a fresh sheet of paper out of the tray, but then beeps a few times and displays a new error..."Functional Problem with Machine. SC2322". The machine will makes noises like it is still working, but then if we wait for about 2 minutes, is processes the fresh sheet it took from the tray and just pushes it through the system with no printing. I double checked every door is closed nice and tight and even made sure the door magnets are clean. Is it still a bad hard drive?
    Sorry, the new error is SC 322, not SC 2322.
When i copy it copies 1 copy then displays error code sc402 and i have to turn off machine and back on to copy
Posted on Nov 13, 2009
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
Posted on May 15, 2009
Trying to replace toner in a savin 9922dp. install the toner cartridge, copier runs like it is loading the toner but then the error message to replace toner appears again (over and over)
take the toner out - whilst the green handle is up (this will get your hands dirty) feel inside for a left over cap from a previous toner. remove it and put your new toner in. this should sort it
Oct 02, 2013 | Savin 9922DP Toner 6 Ctgs/Ctn 66000 Yield...
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
Dec 26, 2009 | Savin Office Equipment & Supplies
SC863
SC-863
DESCRIPTION
The data stored in the HDD
cannot be read correctly.
Bad sector detected during
operation of the HDD
POSSIBLE CAUSES
Defective HDD
Defective controller
POSSIBLE SOLUTIONS
1. Reformat the HDD.
2. Replace the HDD when SC863
occurs more than ten times or it
takes more than twenty seconds
to get ready condition.
3. Replace the controller board.
Apr 03, 2009 | Office Equipment & Supplies
Add toner message
have you tried another toner cartridge? eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Savin 9935DP Laser Printer
1,236 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
