Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Evaporator problem on refrigerator
Ice on the cap tube and liquid line entering the evaporator, the fridge is not getting very cold
  • John Tripp
    John Tripp May 11, 2010
    Can you look and see exactly what model your refrigerator is? I will assume that it is the Whirlpool Top freezer with Ice Magic but if its not that model it will get us both on the wrong track. I believe like most models there is a defrost problem or fan not circulating air inside correctly to take the heat out of your freezer and refrigerator sections. Now I'm going to look up that number above your post will you let me know the temperature inside the freezer? Is air moving well, have you looked at the evaporator coil and if yes what did you see? seabreezehvac@yahoo.com
    If no ice on evaporator and continuous run may have different problem, my-site..I will be here to help and our site offers free help and advice, Thanks, Sea Breeze
    http://servicepartstec.blogspot.com/
If you have a gas leak then you find the liquid boil off very early in the evaporator only, there should be no visible frosting until after the end of the capillary
Posted on May 15, 2009
Water dripping from freezer into refrigerator. Leaking from cold air chase that comes from freezer to refrigerator. Drain line is clear. Leaks more if using ice maker.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Dec 16, 2014 | Refrigerators
LEAKING WATER UNDER CRISPERS, NOT COLD
Jul 18, 2014 | Kenmore Refrigerators
My whirlpool fridge is not working, the freezer is working, I can't understand it. The thermostat inside the fridge seems to be okay, inside the fridge is not even cold. Can you help me. My fridge...
Your cooling comes from the freezer side through cooling tubes to the refrigerator side.
The first thing is to make sure that the evaporator fan is working, because that will blow the cold air into the refrigerator side. If it is working then you probably have an ice build up around the evaporator. You will need to remove the inner rear panel of the freezer to check it.
If there is a lot of ice on the evaporator fins then your defrost circuit is not working. But if you manually defrost the freezer (a hair dryer will speed it up) and make sure the cooling tubes are clean of ice (can feel the air from the hair dryer on refrigerator side) then you will have anywhere from a few days to a few weeks before the ice build up returns.
So you should troubleshoot your defrost circuit and get the parts on order to be ready for the next time.
Jul 15, 2011 | Whirlpool Refrigerators
My whirlpool model et8chmxkt04 refrigerator has water in the refrigerator which I assume comes from the freezer. I don't have visible ice buildip anywhere. Shirley
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | Refrigerators
Model # PSC25PSTBSS low pressure tubing icing up on compressor ref @ 42F has A valve on the high side for cap tubes
Very unusual for a household fridge, but ice build up on the lp side(suction) normally indicates to much charge (gas) in system or if compressor starts to become less efficient, valves dont seat 100% which causes a liquid build up on the line. If the evaporator fan motor stops, this can also create that problem.(assuming the fridge wasnt cooling properly). Many occasions when a new compressor is installed, the technician might put a little to much charge in by mistake. Normally a machine puts in an exact amount that has been dialed in.
Jun 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore AC, no cold air
If the evaporator tube is iced up entering the coil and cool to warm leaving the evaporator, that would indicate low on refrigerant or a restriction. If it is iced up entering and leaving the evaporator, then, it could be low on refrigerant,blower not running at proper speed, dirty evaporator coil or filter.
You need to check the suction and head pressure and temperature to determine problem for sure.
Jun 07, 2010 | LG LWHD1200FR Wall/Window Air Conditioner
Why suction line would ice back
Good day,
Unusual question.
Lots of reasons. You didn't say if it was cooling or cycling off and on.
1. Evaporator fan motor in freezer compartment not running. Doesn't allow the refrigerant to boil off and returns as a liquid.
2. Evaporator coil badly frosted allowing no air flow thru it. Same as #1
3. Runs constantly (days). no demand on system, and once again will not boil off before leaving evaporator.
4. Overcharged. Floods back excess charge.
5. Heat exchanger came apart. The capillary tube is soldered to the suction line to transfer heat from the cap tube to the suction line. Necessary on a refrigerator. Common problem.
Hope this helps
Thanks for using fixYa
Jan 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
Copper pipe in back of fridge frozen , fan is moving but feel no air blowing in fridge..or freezer...
That is called a " cap tube separation " . It can be caused by overlooking a defrost problem for too long . If the coils inside of the freezer frost up , that frost , will eventually work its way out thru the back toward the compressor . When it does this , the " low side ( suction ) " , receives liquid refrigerant , instead of gas . This liquid refrigerant , will destroy the compressor internal valves , causing it to loose the low side . ( Never charge a refrigerator low side with liquid , only gas . The high side can be charged with liquid . ) A cap tube separation , is when the pressurized ( causes heat ) cap tube , becomes separated from the low side ( suction ) tube , causing the suction tube to frost up , due to the cap tube no longer attached to it . When this happens for too long , the only repair , is to replace the compressor AND repair the separation , with wire ties , thermal putty sealant and aluminum tape .
I apologize for the technical explanation , but there is no other way to explain it .
Nov 21, 2009 | GE Refrigerators
Kenmore refrigerator 25364150400 fridge won't get
check your evaporator coil in freezer it is froze up ,need to check to make sure defrost timer is working. Also check drain line.
Apr 10, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
196 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
