Question about Mitsubishi WD-60735 Projection Television
MITSUBISHI WD 60735
NEED TO CHANGE PARENTAL LOCK CODES
tvtek
  • 1284 Answers
SOURCE: I don't have an owner's manual for my wd 60735,
Removing the Old Lamp Cartridge
Turn off TV power a 1. nd allow the lamp to cool for at
least one hour before proceeding.
2. After the lamp has cooled, remove the cover of the
lamp compartment, located on the back of the TV.
Refer to figures 1 and 2. Use a #2 (large) Phillips
screwdriver to loosen the screw securing the cover.
Keep the screw and cover for re-installation
3. With a large Phillips screwdriver, loosen the two
shiny screws securing the lamp cartridge until they
disengage from the mating threads. These are
captive screws and cannot be separated from the
lamp cartridge.
4. Fully open the bag supplied with the replacement
lamp and set the opened bag aside.
5. Gently grasp the handle of the lamp cartridge and
pull the old cartridge straight out. See figure 3.
CAUTION: Do not tilt or rotate the cartridge, as
small glass fragments may fall out.
6. Without tilting or putting down the lamp cartridge,
insert it into the opened bag. Close the bag while
being careful not to let any glass particles fall out.
Installing the New Lamp Cartridge
1.
Do not touch the glass parts of the new lamp cartridge.
Insert the new cartridge into the TV in the
same orientation as the old cartridge. Push on the
cartridge housing until it is fully seated.
2. With either your fingers or the screwdriver, gently
tighten the two shiny screws. If using a screwdriver,
AVOID OVERTIGHTENING!
3. Replace the plastic cover and retaining screws.
4. WASH YOUR HANDS THOROUGHLY, AS THIS
LAMP CONTAINS MERCURY.
Posted on Nov 11, 2009
SOURCE: developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
Posted on Mar 20, 2010
pabloloco
  • 2335 Answers
SOURCE: mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Posted on Apr 30, 2010
  • 5477 Answers
SOURCE: how do you change a lamp on a wd-60735
First order the correct lamp for your TV. Order from www.mitsuparts.com if the unit is out of warranty. The lamp part number is 915B403001. Next make sure the TV is off and has cooled for at least one hour. Use a Phillips #2 (large) screw driver to remove the cover from the back of the TV (on the lower right hand side). Next loosen the two screws (Phillips #2) that hold the lamp cartridge (they do not come completely out of the cartridge). Open the bag that comes with the new lamp and set it aside. Grasp the handle on the old cartridge and pull it straight out. Put this lamp into the bag. (Be careful to avoid tilting or rotating the lamp since that could cause glass to fall out of the unit.)
Carefully handle the new lamp (do not touch the glass - wear gloves if possible), Insert the lamp cartridge into the TV in the same orientation as the one you removed earlier. Push it into the TV until it is fully seated. Tighten the two screws with either your fingers or the screwdriver. Do not overtighten the screws. Replace the cover and tighten that screw.
You can get the manual from Mitsubishi support: http://www.mitsubishi-tv.com/support.html . Click on Product Documents and search for the model number. The directions start on page 75 and includes pictures of the procedure.
I hope this helps.
Posted on Jan 21, 2011
  • 26 Answers
SOURCE: Mitsubishi wd-60735 no picture and red lamp light
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Posted on Oct 07, 2011
-- "wd-60735 lamp was replaced have sound but no
check your Lamp Fan if it stops running when Lamp trys to light ,then it is defective ,but if it is ok Ballast Board could be the problem, it is what Powers the Lamp ON.
Aug 23, 2011 | Mitsubishi WD-60735 Projection Television
How do i change the lock code on my mitsubishi md-60735( 60'' ) tv? also please, why can only turn on and off my tv with only the remote? please help.
The only way to reset on a lock code on a Mitsubishi TV is going to be reseting the unit. I believe this unit is reset by holding down the power button for 10 seconds while the unit is turned on. As for the remote being the only way to turn the TV on, does the button on the front of the unit stick, or seem 'smushy' when you press it?
May 04, 2011 | Mitsubishi WD-60735 Projection Television
The picture is very dark
Sounds like your lamp/bulb is about ready to die. Here is a google shopping list for some replacements if you choose to DIY. http://www.google.com/search?q=Mitsubishi+WD-60735+replacement+bulb&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#q=Mitsubishi+WD-60735+replacement+bulb&hl=en&client=firefox-a&hs=XxY&rls=org.mozilla:en-US:official&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=k7KtTZP4A4jk0QGYm6jHCw&ved=0CHwQrQQ&biw=1366&bih=650&bav=on.2,or.r_gc.r_pw.&fp=30e0fb8dc28dda8
Also if you need help on the DIY just come back. But a detailed reinstall can be found in the manual starting on page 75 which if you don't have can be found here:http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf. Also on that page is a part number and phone number to get replacement direct from Mitsubishi. Good Luck!
Apr 19, 2011 | Mitsubishi WD-60735 Projection Television
How do you change the lamp in a Mitsubishi model WD 60735 projection TV
Try website like Youtube.com,search type in ur tv model,make and projection lamp replacement.U will have somebody,have a tutoring video doing it.
Oct 04, 2010 | Mitsubishi WD-60735 Projection Television
How do i change parental controls without a the
Press the number 9 and QV buttons on the TV remote control at the same time, when the passcode is requested.
Feb 11, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Parentel control
It is fairly easy. Press menu, go to setup and from there, just research or reprogram the channels. This will reset the parental controls. :-)
Jul 26, 2009 | Mitsubishi WD-60735 Projection Television
Developing white dots
Jul 15, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 Projection Television Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
