My fax has stopped receving faxes. What should I check or reset?
Me regalaron un fax 190 sin manual como se usa por favor ayuda para ingresar nombres
The phone line to begin with, can you get a dial tone when you press speaker button? Is it clear? if no dial tone then, Is the phone line from the wall plug into the correct socket of the fax machine ? (it goes into the one marked line, not the ext one)..... next trick would be to plug in a normal phone to wall socket to insure we have dial tone and eliminate it being a telstra fault, Could also be wise to check filter is installed on that line if we have recently installed ADSL Broadband.
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
I am able to send fine but cannot receive any faxes can someone share some light on this?
can send faxes out but cannot rec them......person trying to send fax gets a busy signal or told to enter a pin #. Have went through the manual and tried everything we can think of but to no avail..............................
