Question about Yamaha 12V Air Pump
2006 yamaha waverunner wont idle
I have a 2006 yamaha waverunner that runs excelent once you get going but at idle it will not stay running. The waverunner shows no bad codes, just 01 the normal code. It doesnt have very many hours on it. Does anyone know whats wrong?
    Champion:
  • 207 Answers
What is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
Yamaha waverunner gp1300r turns over want start
I have a 2006 gp1300r an it will start up an idle fine, but when u go to take off it does nothing. What can I do to fix it?
May 31, 2012 | Yamaha 12V Air Pump
Jet ski having to play with choke to stay running
you more then likely have some clogged jets in the carbs. That or a vaccum leak.
Apr 17, 2012 | Yamaha XL700Z Waverunner
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Jul 28, 2009 | Yamaha 12V Air Pump
Wont start now, idled last year but died when throttled up.
sounds like you blew some junk up into the carbs or injectors whatever the casse maybe. if you can try to blow some air through system or get a good cleaner and run it through the system, if its not too bad that should take care of it. These dont like running out of gas, try not to do so in the future. 1 more thing, sometimes a blast or two of ether will help also. Good luck
Jun 17, 2009 | Yamaha 12V Air Pump
I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
Jun 12, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
1,895 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
