No sound from my vizio 32" plasma, worked fine last nite, when turned on this morning it had no sound. Checked all cables and all were fine.
1. I would first make sure that correct "INPUT" setting is registered.
2. Try a different input source such as VCR, DVD or CD.
3. Connect a pair of audio RCA cable to all the VIZIO set's audio inputs one at a time and touch the center tip while the set is powered ON and the input is set to the corresponding seting. If audio circuit is OK you should hear a hum with at least one of the input settings..
4. If still no audio, then it maybe the audio circuit board needs to be checked.
CHECK THE MENU ,,,,MAKE SURE SPEAKERS ARE TURNED ON
