Question about Microsoft Xbox Console
Problem with loading games onto my xbox
I just got an xbox ,and the personb we got it from said he hadn't played it for a while. anyway it dosn't load some of the games that we have , and they work on my friends xbox but not mine. it just says that the disk may be dirty or damaged, but the dicks are com pletly clean.
  • 47 Answers
Re: problem with loading games onto my xbox
Your drive may be getting ready to die or laser may be durty.  Go to your local electronics store and get a lens cleaner.  This should work
Posted on Oct 27, 2007
0 characters
3 Points
Ive transfered my game saves off my old xbox 360 onto a usb and tried to put them onto my new xbox 360 slim but wen i try do it it says not allowed to transfer files so i try to play game and then save it...
the xbox does not allow this in order to stop piracy, you can enable your xbox to play games off a usb if you flash it. its not an easy thing to do but if you want to learn how, look it up on google
Mar 05, 2011 | Video Game Consoles
When turning on my xbox 360, it will not load any games automatically. it says open tray, i open and close tray several times for it to finally load the game so I can play. Also at times when gam does...
This is a problem occurring in all the xbox 360 consoles....... this is mainly because of the poor quality of the disc, a result it leads to the damage of ur xbox lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
all the best.......
click here to download
Dec 07, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
PS3 won't play says loading continuously
go to and repair sevices i used them when my xbox's were dead and they had the red ring and disc read error they can fix it in ten minutes i watched them install a new tray on mine. anyways they have your problems the disc error and freezing. $9.99 but your yellow light $99.99 the cost to see your ps3 run again.
Sep 12, 2009 | Sony Playstation 3 (PS3) Console
Xbox will not load a particular saved game
your xbox hardrive may be full...check to see that you have space on could also be that you have too many Farcry2 games saved on it...if you have multiple games saved, try erasing one that you dont need
Jun 21, 2009 | Microsoft Xbox 360 Console
System can load games, with the exception of one
Try to install the game onto the HDD drive.
To do this simply insert the game onto the drive and go to the menu where it shows the game disc.
Press Y on the image of the game and select "Install to Hard Drive".
After the game finishes install select "Play From Hard Drive"
If the game fails to install try cleaning the disc with warm water NOT hot or cold water but WARM. After that dry the disc with a soft towel or some sort of SOFT cloth by wiping away from the center of the disc.
Jun 15, 2009 | Microsoft Xbox 360 Console
Icant play my ole xbox games on my 360 pro
You need to update for backwards compatibility
Here is a guide on how to do so: Click Here
Apr 26, 2009 | Microsoft Xbox 360 Console
Xbox won't load Hi I have Xbox
It could be the laser needs cleaning, or the game disc itself make sure there are no scratches on the game disc underneath. if other games play and just that game wont then its possible it could be scratched and need of a clean.
Mar 01, 2009 | Microsoft Xbox 360 Console
Xbox Does not play original games
Error Codes XBOX360
Feb 25, 2008 | Microsoft Xbox 360 Console
Playing xbox games on xbox 360 arcade
You need a hard drive.
Once youve got that you simply load up the emulator
Order direct form microsoft / download via xbox live or burn yourself
here is the link
Dec 07, 2007 | Microsoft Xbox® 360 Core System Console
Assassin's Creed
Farhan and Tim
Nov 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
