Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Image green tinted.
I have a 50a 500v Hitachi 50in hdtv. The image is tinted green when it's turned on. Did the color testing thing and green made it green, red made it red, but the screen turned black when I put it to blue. How do I fix this?
  • Anonymous May 17, 2009
    image green tinted. color not right.also double image. do i need a lamp or is there another problem .
    Genius:
  • 1,148 Answers
TRY VIDEO CONVERSION OPTION IN THE MENU,,IF NOT TRY NEW CONNECTERS
Posted on May 15, 2009
I have a hitachi 50vf820 with green tint to it
Its a DLP type set that uses a lamp for a light source.
With the color turned to zero stand back and examine the image.
If mostly all green or areas are green you may have a issue with the optical light engine--either damaged inside from the heat of the lamp or the portion that processes red, green, and blue information bad.
Jun 03, 2012 | Hitachi 50VF820 Projection TV
My LG flatscreen image emits an intermittent green tint and then reverts back to normal colors.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
SCREEN IS DIM, SPOT IN MIDDEL AND ALL COLORS HAVE A GREEN TINT
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 12, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Picture has lots of green
i think that your TV picture tube has a problem..tnx
Sep 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
My screen has gotten much darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 24, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Aug 16, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
920 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
