Question about Samsung HL-R6167W 61" HDTV
Left side of television just started having a shadowing problem?
On my Samsung Dlp Television, HLR-6167W TV, this morning I turned the tv on and on the right side of the flat panel screen, starting at the bottom and working its way all the way to the top was a shadow.  The shadow starts approx.2 inches in width at the bottom left hand side of the screen, and consistently gets wider as it moves up the same side of the tv until reaching the top left side of the tv. (The same side the shadow started from)  At the top the shadow is approx. 4 or 5 inches wide.  If I look at the television it looks like a small V shadowed in.  I can see the picture behind the shadow.  But it is a extremely dark shadow.  (UNACCEPTABLY DARK) so the picture behind it is barely visible yet still there.  Almost as if the tv picture fell of kilter to the right, but the pictureis still seen underneath this weird shadowed line.  Impossible to burn in, I THINK, in the design that the darkness is in.  Is it simply a new light bulb that needs replaced.  If I pull 4 X 3 down or anything that isn't 16 X 9 its picture perfect.   When the tv's off the shadow is gone, so its not on the screen itself.  Please help.... Thank you.
  • 2 more comments
  • BDW1234 Dec 05, 2007
    Nothing done to date.
  • DeniseEgon Dec 27, 2007
    We have the EXACT same problem, however, ours is on the right side of the screen. Our Samsung is only about 14 months old (we are looking for our paperwork to see if we bought the extended warranty - hopefully we did!). We are so disappointed...the tv has been great up until this point.
  • Anonymous Apr 25, 2008
    red shadow on everything
  • Anonymous May 03, 2008
    Same as above. Just replaced lamp, shadow still there.
I can't find the parts section when I go to BestBuy's websight.
Posted on Apr 18, 2008
The problem is with the light tunnel. It is available from the parts sections of the Best Buy website for less than $50.
Posted on Apr 03, 2008
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Posted on Feb 08, 2008
2 Suggested Answers
SOURCE:
tvguy171
  • 106 Answers
SOURCE: samsung dlp HLR 6167w turns
If you have not replaced the lamp, that is the first thing I would do. If the lamp has been replaced, the colorwheel is the next culprit. Hope this helps
Posted on Dec 07, 2008
Dark shadow on samsung lcd tv
shadows being left when turning sumsung lcd television over
Feb 25, 2010 | Samsung TXR3079 TV
Poping sound last night now humming with no picture,unplugged tv due to not turning on/off normaly.HLR 61" DLP
It may cause by color wheel breaking off. Do not turn it on again, it will cost you more to repair. Call service for repair. If you can do it yourself, contact me I will tell you how to replace it. I can help repairing if you live in Orange county or Sandiego.
Oct 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My dlp tv has a shadow about 6'' wide and full ht of tv
Hello: The problem is that a small mirror on the light tunnel has fell off causing a shadow in the picture,. In the past the only way to repair this problem was to replace the entire Optics Engine. But Samsung decided it was replacing entirely to many light engines so they decided to allow and train technicians on how to do it. It involves removing the color wheel and behind it is the light tunnel where light from the lamp shines on to a maybe 1 1/4 inch small block with three mirrors on all sides, your problem is that one of these mirrors has come loose from its side, causing a shadow with the pic still in the background. So if you call a technician to come, if he has'nt had the training from samsung on how to do the procedure then he will want to replace the entire optics engine which is the expensive way of doing it.
So when calling as if they know how to replace light tunnel. There are some adjustments that also needs to be done once it's replaced. To verify what i am saying go to this site to find out more. http://www.avsforum.com/avs-vb/showthread.php?t=758625
Call if you need more info will be glad to help..
Delhielectronics@live.com
Phone: 702-418-1389
Sep 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP TV HL-R5067W green vertical bars on screen no picture
This is going to be a bad digital board. It is a very common issue with the HLR series.
Aug 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung dlp HLR 6167w turns off
Dec 07, 2008 | Televison & Video
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6167W 61" HDTV Logo
1,290 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
