Question about Vizio P50HDTV10A 50 in. Plasma HDTV
TV creates LOUD sound when turned on. sounds like a blow horn.
It does not do this sound ever time it is turned on, but it does it frequently. seems to happen 1 out of every 3 times it is turned on. It is so loud that it woke my neighbors one night. The picture shows up just fine... it just does this horrible loud sound.
  • Vizio Master
  • 3,866 Answers
Manufacture is recalling most of these and I am aware of this issue contact the manufacture to have them fix it for free.. Thanks
Rulds2008
Posted on May 15, 2009
My ford excape sounds the horn once loud and locks the doors like it's going to start then just beeps 3 times loud plz help
Try resetting your remote device by holding it near the front drivers side and press and hold the emergency button until the horn blows once. See if that does the trick.......
Nov 08, 2014 | Ford Escape Cars & Trucks
Horn blows when turning volkswagon passat
if you want to disconnect the horn, the easiest way is to locate it under the hood and remove one of the wires connected to it.
Nov 08, 2013 | 2003 Volkswagen Passat
350Z horn not sound loud
You have 2 horns,high and low,check out the connections there and the ground,could just be loose,not normal for horns to go out at this year.Have some one blow horn and listen to both to make sure both are working,One might be bad,or connections are rusted,get sand paper and rough up to get better connection,if this don't work,guess what,as you know,horns are not cheap,replaced mine on my 85 Nissan 720 4x4.Now they are loud.
Jun 02, 2013 | Nissan Cars & Trucks
Horn does not work
This is common with Harley's horns. There is a screw on the backside of the horn. Turn this screw in very small increments until the horn starts sounding again. If it never does, you need a new one. Make sure you check the ground on the horn.
Jul 27, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
'99 Nissan Maxima - 298K miles: Car won't start...Weezy sound...
Sounds like your solinoid is bad on your startermotor. Replace with known good starter. If you want to check it out then pull the startermotor take it to your local auto parts store and they can verify it.
Dec 09, 2009 | 1999 Nissan Maxima
Horn sounds weaker than usual
There are two horns on this vehicle. Check to make sure they are grounded properly, and if you have a volt meter, disconnect the horn wire, have someone push the horn button while you check the voltage on the wire. You should get at least 12 volts. If the horn has a good ground, and is getting the required voltage, then you probably have a bad horn. Disconnect one at a time, and see how loud each of them are. This should help determine which one, if not both is causing the problem.
Mar 26, 2009 | 2003 Nissan Altima
Car makes loud noise on passenger side near head light.
sounds like the blower fan. what type of chevy is it. a full size has the fan on the passenger side firewall. should be easily accessible. just disconnect the wire and test the car. if it stops making noise , that is the problem, also turn on the fan speeds to different settings, if if changes sound , that is the problem
Aug 09, 2017 | 1986 Chevrolet Nova
Weird, annoying noise every so often
Is this happening on just on input?
If so... Check your connections. If you are using the component cables, make sure you haven't plugged the right audio into the red video input. it's a common mistake. I see it all the time.
If this is happening on all inputs, be sure the noise is coming from the speakers. Then replace the main board.
Nov 28, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
154 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
