Question about HP OfficeJet 6110 All-In-One InkJet Printer
Refillied black ink cart. causes error.
After inserting a refilled black ink cartridge, we get the error: Right cartridge incorrect. This is the first time this cartridge has been refilled and it worked fine just a few hours before it was refilled. Any suggestions?
  • angelaandron May 15, 2009
    Remove and check right cartiridge... fault. Changed cartridge got this fault, then I put old cartridge in and continue to get this fault.
    Please help!
    Thank you
    Problem Solver:
  • 10 Answers
The ink cartridge is bad get a new one after a few times of refilling the ink cartridge they go bad. Hope this helps ya
Cheers
Johnthetr870
Posted on May 15, 2009
Printer keeps flashing print cartiagein right not supported..alos comes up on screen stating cartiage on right side is not intended for this printer. I have been using this cart. for awhile now it is the...
There is a problem with the computer sensor in the ink cartridge. That is what is causing this error that you are seeing. Is it a refilled cartridge or did you buy it new from the store? If you bought it new and it is doing this, then take it back to the store and tell them it is a defective cartridge and you want to exchange it for a new one. If it is a refilled cartridge and you bought it from an ink store, take it back to them and tell them that the sensor is failing. They will replace or repair the sensor and then the cartridge should work properly.
Hope this helps?
Nov 08, 2010 | HP PSC 2355 All-In-One InkJet Printer
Had ink refilled at costco...now printer wont recognize cartridges
your cartridge have not been refillied in the right way
you must replace the chips with new ones
May 13, 2010 | HP Photosmart C5180 All-In-One InkJet...
I had my black ink cartridge refilled professionally, and printed several pages before receiving an "Error: Incorrect Cartridge" message. The printer is also making a loud grunting sound when I turn it on...
you have 2 different problems
1)  "Error: Incorrect Cartridge"  you get cause your cartridge had air bubbles inside and that damage the printhead
air bubbles must be removed before use ether with a vacuum refill or a refill clip as this video
http://www.youtube.com/watch?v=dhDaKSzou50
2) the loud grunting sound you get it either couse the cartridges are stuck or cause paper is stuck in the paper path and do nt let the cartridge carrier to move free
Jan 15, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Problem with hp deskjet 640c printer
i have an hp and find that they (color carts) cannot be refilled- the clever b*st*rds!! they stepped the ink reservoirs so, if you don't insert the re-fill needle 'just right', it bleeds into the others and you end up with a 'muddy' print-out! you need to buy a new hp cart, or shop around for a generic cart (cheaper) google your product & cart #. you may find a source for a cheaper cart.
the black carts. can be re-filled!
good luck!
Oct 08, 2009 | HP DeskJet 882c InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Cannot get the printer to accept the new HP black cartridge
Make sur u r not using refilled carts...
Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier..
And install the carts thru the HP software..this might fix..or the carts are defective
Jun 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
Is there a way to get Brother MFC-240C to only use black ink cartridge?
Theres a simple trick to cheat the machine.
BUT
you will definitly destroy the printhead when doing so for a longer periode!
You have to put some black adhesive tape around the middle part where you can see this black palstic flag inside the cart. This flag signals the printer that the cart is insert and later on when the ink is down to give the waring: near empty.
I do give you the advice to do another but saver cheating:
You can refill the cart with a mixture of 8 ml destill water and 3ml 85%-Glycerol (e. g. Glycerin alc. which can be bought at a drugstore for a few cents). Shake the mixture well (within the syringe) before refilling the cart.
See pics here how to do so (LC1000):
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(brother has changed the construction of the carts! If you can see a plastic quad in the middle of the cart, you have to drill the hole just behind the air valve (white plastic looking out of the cart)
Feb 24, 2008 | Brother Multi-Function Center MFC-240C...
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
395 people viewed this question
Seeker5211
Seeker5211
