Question about Dell 1200HS D1226H (White) 19 in.CRT Conventional Monitor
Monitor reads: NO SYNC INPUT
I intended to put my hard drive into another computer. The other computer wouldn't read the hard drive. When I returned the drive to my computer, and booted up, the monitor never showed anything but - no sync input.
  • 2 more comments
  • Peenyuh Oct 15, 2007
    I just thought of the power supply and put a new one on. no dice. Thank you , though.
  • Peenyuh Oct 16, 2007
    I'm going to buy a new WGA card soon. Everyone assures me this is my problem...and I believe all of you. I'll let you know if it works. Thank you for your time.
  • chipinapi Mar 24, 2008
    monitor reads NO INPUT SYNC
  • Anonymous Apr 01, 2014
    i just want to know what it might be with this computer? it does not show anything on the m onitor when i turn it on!!!
  • 1,006 Answers
YOU HAVE TO CHANGE POWER SUPLY ( buy new )
Posted on Oct 15, 2007
  • arben pllana
    arben pllana Oct 15, 2007
    ok then check your WGA and make sure that is propertly connected...If u have another monitor try it or if u have another wga card try it
Disk read error
1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi...
or rather than doing this try the alternative which is windows own repair
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any
bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
also download a registry cleaner
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
hope this helps
Sep 28, 2012 | Dell Latitude E6410 Laptop Computer (Intel...
Why no video
a HP monitor. as old as 2006... (o0ps)
read the manual yet? on "power saver modes" turn off them?
i bet you dont know spec, on caps. it's not published by HP ever.
most are +80% - 20% for filters. (ever seen that?)
so a 100uf can read 180uF, or 80uf and is IN SPEC.
but no caps stated, by you, lots there are...
my guess you are
looking for the caps used in china long ago that all failed, every one.
first off you never fully stated whats wrong, in DETAILS.
first have good running pc , with live VGA output (using VGA are you)>? unstated...
the MON, will now live sync, now , Horz and vert, on both pins
the OSD screen now works, if not the monitor is bad.?
or see No/syn, no sig, out of range or no input errors.
Monitor Going to Sleep
see page 34? in your manual yet?
and page 31, turn of power saver ?
if OSD is dead, say so first.
OSD can be locked. push mon menu button for 10sec, now unlocked
then go to OSD screen
http://h10032.www1.hp.com/ctg/Manual/c00834092
Power-Saver Feature
When the monitor is in normal operating mode, the Power li
ght is aqua-white or green (depending on model) and the
monitor uses the normal watts of power. For power us
age, refer to "Technical Specifications" (Appendix B).
The monitor also supports a power-saver mode that is
controlled by the computer. When the monitor is in the
reduced-power state, the monitor screen is
blank, the backlight is off, and the
Power light is amber. The monitor uses
minimum power. When the monitor is "awakened," a brief
warm-up period occurs before the monitor returns to
normal operating mode. The energy-saving reduced power stat
e activates if the monitor does not detect either the
horizontal sync signal or the vertical sync signal. The powe
r-saver feature must be activated on your computer for this
feature to work, << read that carefully?
turn this off ? first?
osd-vboix4tqi2kfzapulla5cn4x-5-0.jpg the early models of the monitor
had CCFL back lamps, and the 2 inverters are on the main power board. left side here
http://i.ebayimg.com/images/g/2-wAAOSwzSRZxoWH/s-l1600.jpg
Sep 28, 2017 | HP Compaq WF1907 19" LCD Monitor
Hard drive won't read
can you see the drive ? if yes
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Feb 24, 2012 | Maxtor One Touch II (EO1E200) 200 GB Hard...
My Toshiba Canvio 320 made a loud clicking noise when I first plugged it in to either of my computers. It wouldn't open but I would be instructed to format. I kept trying it and it finally formatted....
if usb port could not power well , the hard drive is clicking. there for use the power cable can connect 2 usb ports and use short thick cable, if you can return it clicking when copping or reading , if it has bad sectors pls return, when reading bad sectors head may parking to increase the magnetic field, there for giving sound clicking,
Sep 29, 2017 | Toshiba (PA4148E1HC2) 320 GB USB Hard...
Parts of computers and its function
Computer: A machine that processes information and performs computations.
Tower or CPU: The "box" or case that holds the parts that make up a computer: CPU, hard disk drive, floppy drive, memory chips, power supply, interface cards, etc.
CPU: Central Processing Unit, or "brains" of the Computer.
Monitor: An output display device (looks similar to a TV) in a computer system. You see information on the monitor's screen.
Screen: The viewing area on a monitor or the information or image displayed.
Disk Drive: A device that reads data from (input) or records data onto a disk for storage (output).
Hard Drive: The main device that a computer uses to store information. Most computers come with a hard drive, called drive C, located inside the computer case.
CD-ROM: ROM means Read-Only-Memory - you can only "read" information, not save. A CD can store a large amount of data including documents, photographs, software, and music (about 20 songs)
Mouse: A hand-held input device you roll on your desk to point to and select items on your screen. When you move the mouse, the mouse pointer on the screen moves in the same direction.
Speakers: Output device that produces sound and music when connected to the computer. Speakers come in different shapes and may even be in the monitor's case.
Headphones: Output device for listening that is held over the ears by a band worn on the head.
Microphone: Input device in which sound energy is changed into electrical energy for the sending or recording sound (your voice).
Scanner: Input device that reads copy as an image and digitally records the image.
Jul 05, 2010 | Dell Inspiron 530 Desktop Computer
Seagate external drive locked in "read only" ,was working fine...
This seems to happen when it's been connected to another computer. Are you running FreeAgent Sync? If so force a sync and the read only problem should go away.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer won't read hard drive in bios nor on start up
The first step is to ensure the hard drive is functional. Test it on another machine. Then check if the computer has the ability to read the newer drive. There may also be a bios update that may allow recognizing the newer drive.
Dec 03, 2017 | Seagate (ST3120026AS-RK) 120 GB Hard Drive
My passport "removes" my files!
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a
computer to the drive (WD Passport) and SHOULD NOT be used as backup
software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as
this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the
WD Sync software, reformatting, and using the WC Passport as a true backup
drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Studio 9
Make sure that all background programs are not running on your computer. This includes, IMs, Anti virus, email programs. Defrag your hard as well. Your captured material may not be on contiuous file on the hard drive but fragmented into pieces.
What type of processor do you have in your computer and how much memory does it have?
Make sure that you run the PCI performance wizzard as wall as all calibration programs within Studio 9. Make sure that your DVD has recording enabled. This can be done by pressing my computer, pressing the right mouse button on the drive, select properties, select the recording tab, check enable CD recording on this drive. You may have to adjust the recording speed as well if the DVD player has trouble reading it.
Jun 09, 2008 | Pinnacle Systems Studio AV/DV Version 9...
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Dell 1200HS D1226H (White) 19 in.CRT Conventional Monitor Logo
771 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
