Question about Apple iBook G4 1GHz 256mb 40GB Combo 14" -Pre Owned Mac Notebook
Mac G4 Blue screen only after restart
After a 'security update' I restarted my Mac G4 computer. When it loads a gray screen with the apple icon appears followed by a blue screen. I do not know why it doesn't let me go any further. I have tried diagnostic repair in the installation disk but that didn' t solve the problem. If you can help me out it would be greatly appreciated. Thanks!
    Genius:
  • 1,148 Answers
Use system restore ,,
Posted on May 17, 2009
How do i shut mac off then put start up disk in ?
Simple. Load the Apple System start-up disc first while the computer is running. You should see its icon on on the screen. Then select restart from the Apple Menu on the top left of the screen. Hold down the C key as it reboots. You will now boot into the start-up disc. This method also applies to Disc Warrior and other tools. Alternately, with the computer already running, insert the Apple System start-up disc then go to System Preferences also under the Apple menu, Under the start-up disc icon, select your apple system icon and restart.
Third alternative. With the computer running insert Apple System start-up disc. Restart the computer. Before the chime, press and hold the option key, left-hand bottom side of the keyboard to the left of the Apple (Command) key. You will see your system HD icon and the screen as well as your Apple System disc. Click on the System Disc and that will boot the machine.
Jul 09, 2014 | Apple iMac G4 Desktop
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
My powerbook g4 is not starting. it opens the gray screen and just says i need to restart the computer. i tried restarting it and removing the battery a bunch of time and nothing is happening. HELP!!!
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Powerbook G4 to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Powerbook G4 and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
At times this procedure does help for gray screen issues so give this a try and let me know if this helps.
Thanks!
-Mactechtrainer
Jan 25, 2010 | Apple PowerBook G4 Mac Notebook
HELP!!! I am trying to start my Powerbook G4 but as soon as it turns on I just get a grey screen that says that i need to restart my computer. i tried restarting it like 10 times. what else can i do?
Also, check your RAM bay port to see if one of the RAM boards came dislodged and is not inserted correctly. Could also be one of your RAM boards is not compatible or one of the RAM boards is defective.
Mac not loading
Try resetting your pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Aug 28, 2009 | Apple eMac G4 Desktop
When i stert my g4 imac,s screen was became blue
You need to reset your pram
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
Powerbook G4 Laptop not starting :-(
sotware is awry 1. put in your system disk and restart holding the c key 2. when the screen shows hit continue 3. go to utilities in the header menu 4. select disk utilty 5. select repair permissions 6. select repair disk after the permission repair is complete 7. quit utility go to start up disk  select your hard drive and restart good luck
Apr 01, 2009 | Apple PowerBook G4 Mac Notebook
Stuck on the restart your computer screen.
You may have installed something in the startup items folder that your mac isn't liking.
When you turn the iBook on, press the shift key as soon as you hear the startup tone. hold it down until you see the gray apple screen. This will get you into safe mode, hopefully then you'll be able to fix whatever you did from there. If you are still at a loss, get in touch.
Dec 11, 2008 | Apple iBook G4 Mac Notebook
Apple iBook G4 1GHz 256mb 40GB Combo 14" -Pre Owned  Mac Notebook Logo
323 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
